Over-Engineering An Egg Cracking Machine
Eggs are perhaps the most beloved staple of breakfast. However, they come with a flaw, they are incredibly messy to work with. Cracking in particular leaves egg on one’s hands and countertop, requiring frequent hand washing. This fundamental flaw of eggs inspired [Stuff Made Here] to fix it with an over-engineered egg cracking robot.
The machine works on the principle of scoring a line along an egg shell to weaken it, then gently tapping it to fracture the shell. A simple theory that proved complex to build into a machine. The first challenge was merely holding an egg as eggs come in all shapes and sizes. [Stuff Made Here] ended up settling on silicone over-molded with a 3D printed structure. After numerous prototypes, this evolved into including over-molded arms for added stiffness, and a vacuum seal for added rigidity.
After making two of these holders, [Stuff Made Here] added them to a roughly C shaped holder, which could spin the egg around, and slide the holders to allow fitting any egg shape. To this was added an arm which included a scoring blade and tiny hammer to crack the egg. The hammer can even be turned off while the blade is in use.
The over-molded egg holder
The mechanism runs off a sequence of score, hammer, dump, eject. It was attempted to run this sequence off a single crank, but ended up not working for a number of reasons, not least of which being some eggs required more scoring then others. Nonetheless, we love the mechanical computational mechanism used. Ultimately, while frivolous, the project provides a wonderful look at the highs and lows of the prototyping process with all its numerous broken eggs.
If you like over-engineered solutions to simple problems, [Stuff Made Here] has you covered. Make sure to check out this automatic postcard machine next!
20 thoughts on “Over-Engineering An Egg Cracking Machine
  1. Cracking in particular leaves egg on one’s hands and countertop,
    What in the world are you doing when you crack an egg open? You hit it on the edge of the bowl, that’s it. That’s all you have to do;)
    1. And what’s with using two hands?
      My kids could do it single handed by about 12 years old (as soon as the hands were big enough). To be fair, I humiliated them when they used two hands. Got to give them some trauma to resent, or they’ll never leave home.
      1. Sounds pathological… I’m gonna go out on a limb and proclaim with no evidence that the number of people harmed by this are easily within the error margin of zero.
        Also the chance of getting salmonella from raw eggs is ~0 as well.
  2. In my mind, I use a laser to make a tiny hole in the egg,put a vacum hose and collect everything…then I use pump hose to add chocolate and let it stay in the freezer…later i use a drillbit to produce chocolate dust to eat…then I use… but that just me being me.
    1. Oh wow, small packs. Standard packs here are 12 eggs. The packs I buy have 30 large eggs. Usually buy two packs at a time. The grocery store across the street closed so I don’t want to travel every other day to buy eggs. 60 eggs is fine for 2 weeks. It’s my main source of protein.
  3. Just in time for some from the Purdue engineering community living in Lafayette, we can have home poultry hens now. Eggs! Opportunities for coop accoutrements and defenses, all legalized now.
Leave a Reply to MaxbashCancel reply
