Although most modern cars have moved to using proprietary components nearly everywhere, especially when it comes to infotainment systems, for a brief moment which peaked in the 90s and 00s most cars shipped with radios that fit in a standard size opening called a DIN slot. If you wanted a new Pioneer or Kenwood stereo it was usually a simple matter to slide the factory radio out and put your choice of aftermarket head unit in its place. [Stefan] has an E39 BMW from this era and wanted to upgrade the factory radio but use the original hardware instead of replacing it.
This isn’t just a simple stereo upgrade either. [Stefan] has gone all-out for this build which he started in 2020. Beginning with a Kotlin/Jetpack Compose Linux application to handle control input from the vehicle’s various knobs and buttons he moved on to a map application and an on-screen keyboard. From there he implemented VGA to send video to the OEM screen, and now has a fully functional system based on a Raspberry Pi. It does everything the original unit can do including playing music and showing the feed from the backup camera, plus adds plenty of new, modern features like Bluetooth.
For a certain classic car enthusiast, this build hits a sweet spot of modernizing a true classic like the E39 without removing or permanently modifying any OEM components. The amount of work that went into it is pretty staggering as well, with [Stephan] putting in over 100 hours of work just to get the video signal timing correct. We also like it because it reminds us of the flash-in-the-pan “carputer” trend from the late 00s where people in the pre-smartphone age were shoving all kinds of computing horsepower in their trunks.
I wonder how easy this would be to implement in a modern car.
I’d sure prefer not to be spied on as I drive, but my 2006 range rover sure isn’t gonna last forever.
The few (Western*) infotainment systems I’ve looked at run some variant of embedded Windows or Android so it may be possible to get root fairly easily on the Android ones at least.
If you can root the device then lots of things become possible but you need to be careful as they are hooked into the CAN bus and ‘unintended stuff’ could happen
As for spying on you, I guess you could just wait for the cellular technology to age out and then buy a ‘new to you’ car that used the old cell tech.
Or, you could go the long route and gut the unit to fit your own hardware inside like this project.
I’ve yet to dig into and explore the Japanese head units I bought but they look interesting, multiple SD cards, even a spinning rust hard disk drive! There is a little info which suggests, at least some of them use Android too and even a couple of videos showing them being ‘rooted’ so apps can be sideloaded
You could make it last forever if you really wanted
It’s not that you wanted a new radio, but rather needed a new one after previous was stolen.
Was it really a brief moment in the 90’s? I feel like you could put a two knob five button radio in most cars for a lot longer than that, like I had one in my 1970’s jeep and found something that would fit in a late 1960’s oldsmobile, and while the kenwoods weren’t five button, they had the same general dimension, including the spacing between the volume and tuner knobs.
And if it didn’t fit, a Dremel could make it fit.
Ha, a Dremel. Andrew Camarata installed a new car radio using a chain saw to make it fit.
The fun part is that he was not doing that for Youtube views, but simply because it was the first tool he came across that “could” do the job. The result was surprisingly not as bad as expected.
Absolutely! As a teenager I mounted a single-din rectangular radio in my 1984 Caprice Classic. The only thing that got in the way was the trim piece. But… the part where the knobs went was recessed so it was really easy to just cut out the recessed part and the result was a fairly clean DIN sized hole. The radios of course had bezzles so if your cut wasn’t 100% pro-looking that would get covered up anyway.
It was an easy job and you wouldn’t know it wasn’t factory without taking it apart!
But different wiring connectors at the back, of course!
I don’t know what the author is on about, most cars (though admittedly no longer all) still come with a 2-DIN unit that can be easily replaced with an aftermarket one using the proper trim adapter.
Not really. While basic audio connection may work, there’s a lot of fancy stuff delegated to a head-unit. On some BMW for example PDC and some other sound signals stop working if you swap the unit, because they are interpreted from CAM messages by it and played through speakers. Play controls on the steering wheel is another thing needs to be hacked after “easy replacement” of a “standard” head unit.
I dunno, I find most of the aftermarket ones jarringly different to the original car aesthetic, it’s not something that would stop me (I’d definitely keep the old head unit somewhere safe though) but there are a lot of people who really like to keep their cars looking as original as possible.
No, it absolutely wasn’t a brief moment. The standard was added to ISO in 84 but I am pretty sure cars going back at least into the 70s, probably earlier than that (before my time) used the 2-knob standard which was the same size except it had wings covering the sides to go around the knobs.
People used to install CB radio transceivers into their cars..
So I think that the DIN bay for auto radios is quite old.
Germany Wikipedia says something about 1963..
“The international standard ISO 7736 from March 1984 standardizes both the installation spaces and connections for front-mounted car radios in road vehicles.
While a minimum depth of 160 mm is specified for the slot, the front panel is defined in two different height variants (50 and 100 mm) with a width of 180 mm.
This standard was transposed into German national standards as DIN ISO 7736 in April 1984 and into Austrian national standards as ÖNORM ISO 7736 in September 1986 (as of May 2013).
However, car radios already had DIN slot dimensions with a height of approximately 50 millimeters in 1963.[1]*
https://de.wikipedia.org/wiki/Autoradio#Einbauma.C3.9Fe_nach_ISO
I just had a dream about an E39 M5 last night. Nothing more constructive to ad. Just reminded me how much I want one.
Add* ugh
I still drive one of the last F31 320 diesels with manual transmission. Probably my last manual ever… :-(
I guess the BOM costs would be higher than the value of my E39…
“for a brief moment which peaked in the 90s and 00s most cars shipped with radios that fit in a standard size opening called a DIN slot. ”
One of the few things I wish they made required by law.
The first thing I do after buying a car is replacing the radio. My current car has an Android radio I bought of one of the chinese web stores. It’s so nice. I bought my current car I think 6 years ago and replaced the head unit a week or two after I got it and it’s still working. Besides it being stuck on Android 9, it works much better (for me) than stock headunits of brand new cars. I got Spotify, Waze, automatic rear view camera based on gearbox info, ODB2 readout, tire pressure monitoring, dashcams, all working with that head unit. And when I’m bored because I’m waiting for the ferry or a bridge that’s open, or I’m eating in my car, I can even turn on YouTube or stream movies through Jellyfin. I got a sim card in it so it doesn’t connect to my phone.
That’s interesting! If it has an spare USB port, it could connect to an USB RTL-SDR dongle and run SDR Touch software.
Or run an ISS tracker applications, run DOSBox etc.
I did such things on an Android TV in living room once, to demonstrate amateur radio and the SWL hobby.
Their faces when Windows 3.1 booted up with all the classic software of what felt from centuries ago! :D
Hey, that’s good actually!
Traditionally, most Android applications ran from 4.4 onwards (or 4.0.4 in the early-mid 2010s).
So having Android 5 or 6 is good enough in most cases.
Also, Android prior version 12 still supports 32-Bit applications, making Android 10 or 11 a sweet-spot in terms of compatibility.
These versions all still support old APK file format for applications, too.
Beginning with Android 16, normal manual installation of software will be re-named “side-loading” as if it was something shady. AFAIK.
“Beginning with Android 16, normal manual installation of software will be re-named “side-loading” as if it was something shady”
Say what? Sideload is an adb command for, well, sideloading apps on your android device. That’s been available since Android 4.1.
Perhaps what you’re thinking of are the new restrictions that won’t let you installed random unsigned apps you download from the phone itself, but rather they would need to be sideloaded from a connected device. Nothing shady about that, just sadly an extra layer of protection, since not everyone is careful about what super looking app they decide to install that’s not from the play store so we all have to suffer for the greater good.
Since adb can be used wirelessly, I wonder what steps would be needed to have an app on the phone that ‘wirelessly’ (or at least fakes it) connects to adb running on said phone to skip the extra device step for sideloading.
Maybe implementing something like HUDIY would be also interresting https://hudiy.eu/
This is great to see! I have 2 E38’s and want to keep that look while getting the upgrades and flexibility something like this offers
