Wouldn’t it be nice to 3D print an entire custom tire for small robots? It sure would, so [Angus] of [Maker’s Muse] decided to investigate whether nifty new filaments like expanding TPU offer anything new in this area. He did more than just print out a variety of smooth tires; he tested each with a motorized platform attached to a load cell, driving on a dusty sheet of MDF to simulate the average shop floor, or ant weight combat robot arena.
Why bother making your own wheels? As [Angus] points out, when one is designing their own robots from scratch, it’s actually quite difficult to find something off the shelf that is just the right size. And even if one does find a wheel that is just right, there’s still the matter of fitting it to the shaft. Things would be so much easier if one could simply 3D print both wheel and tire in a material that performs well.
Here’s what he found: Siraya Tech’s TPU air filament (about 70A on the Shore hardness scale) performed the best. This is TPU plus a heat-activated additive that foams up during extrusion, resulting in a flexible print that looks and feels more like foam than usual TPU. It makes a promising tire that performs as well as it looks. Another expanding filament, PEBA air (also from Siraya Tech) didn’t look or perform as well, but was roughly in the same ballpark.
Both performed better than the classic DIY options of 3D-printed plain TPU, or laser-cut EVA foam. It’s certainly a lot less work than casting custom tires.
What about adding a tread pattern? [Angus] gave it a try. Perhaps unsurprisingly, a knobby tire has worse traction compared to a smooth tire on smooth MDF. But sometimes treads are appropriate, and as [Angus] points out, if one is 3D printing tires then adding treads comes at essentially zero cost. That’s a powerful ability.
Even if you are not interested in custom wheels, that foaming TPU filament looks pretty nifty. See for yourself in the video, embedded just below. If you find yourself finding a good use for it, be sure to drop us a tip!
TPU is still too slippery I guess, compared to rubber. You can easily print a mould to cast silicone rubber. If you use the ‘wrong’ mixing ratio of parts a and b you can get something that’s very sticky. Good for traction, though if it gets dirty after a while the stickiness will reduce. Silicone rubber comes in different shore hardnesses too, and can be adjusted with additives.
I’ve made moulds for casting custom ear plugs with very low shore value silicone rubber. It’s super soft and you barely notice them that they’re there. Great for sensitive ear canals.
Curing time is of course long, about 8 hours. But it’s not too bad.
Both techniques can be combined to give something even better.
Either over-cast or paint on the silicone on the outside of the tire and the better traction can be enjoyed while also benifiting from the lighter foam core (which can even be printed with light infil)
Why bother? Just do a steel(plastic) rim/wheel and tiny layer of grippy material on the od.
Wait, did we just invent the modern car wheel?
Modern idiot’s car wheel perhaps.
‘Rubber band’ tires just suck in every way.
Except display and breakage of status symbol large diameter wheels.
Sidewalls are important parts of a cars suspension.
Leave TPU in humid air, and it’ll pick up its own heat-activated additive that foams up during extrusion. I wonder how (or even, if) the additive in this differs from plain ol’ water.
The MSDS for that Siraya Tech TPU Air seems, shall we say, imperfect? I’ve never heard of a 3D printer filament that’s “Black liquid at 25°C”.
Well, there’s that new silicone filament that’s liquid in a shell of sort in a filament roll, but I think it was silver
Is it an open or closed cell foam?
Wheel and tire sizes…
It’s not that difficult to survey what’s cheep and available before you start.
Wheel and tire rabbit hole…
He really thinks he can do better?
Pretty arrogant, his time though.
No better way to learn humility then trying to improve in a space so done.
$10/4 for RC car pneumatic tires/wheels about that size on alibaba.
Notice he didn’t use any sort of commercial control tire.
Bad scientist (WHACK).
They’re for combat robots, designed to take hits and keep running which an RC pneumatic tyre won’t. Bad commenter.
