If IRobot Falls, Hackers Are Ready To Wrangle Roombas
Things are not looking good for iRobot. Although their robotic Roomba vacuums are basically a household name, the company has been faltering financially for some time now. In 2024 there was hope of a buyout by Amazon, who were presumably keen to pull the bots into their Alexa ecosystem, but that has since fallen through. Now, by the company’s own estimates, bankruptcy is a very real possibility by the end of the year.
Hackaday isn’t a financial blog, so we won’t get into how and why iRobot has ended up here,  although we can guess that intense competition in the market probably had something to do with it. We’re far more interested in what happens when those millions of domesticated robots start getting an error message when they try to call home to the mothership.
We’ve seen this scenario play out many times before — a startup goes belly up, and all the sudden you can’t upload new songs to some weirdo kid’s media player, or the gadget in your fridge stops telling you how old your eggs are. (No, seriously.) But the scale here is unprecedented. If iRobot collapses, we may be looking at one of the largest and most impactful smart-gadget screw overs of all time.
Luckily, we aren’t quite there yet. There’s still time to weigh options, and critically, perform the kind of research and reverse engineering necessary to make sure the community can keep the world’s Roombas chugging along even if the worst happens.
The Worst-Case Scenario
So let’s say iRobot folds tomorrow. What’s likely to actually happen to all those Roombas?
Well, the good news is that there’s no reason to assume the offline mode will be impacted. So pressing the “Clean” button on the top of your Roomba will still get the little fellow working, and the basic functions that allow it to navigate around a room and end up back on its charging dock are handled locally, so none of that will change.
But if iRobot’s servers go dark, that means the smartphone application and everything that relies on it is toast. So you’re going to lose features like scheduling, and the home mapping capabilities of the newer Roombas that allow it to understand directives such as “Clean the kid’s room” are also out the window.
Thankfully, even the newest Roombas can function offline — but not all features will be available.
Looking further ahead, it also means that your Roomba isn’t going to be getting any firmware updates. This probably isn’t a big deal in a practical sense. So long as you haven’t run into any kind of show stopping bug, any future updates would probably be minimal to begin with. But there’s always a chance, albeit slim, that a security vulnerability could be found within the Roomba’s firmware that would let an attacker use it in a malicious manner. In that case, you’d have to decide if the risk is significant enough to warrant chucking the thing.
Even further ahead, replacement parts will eventually become a problem and obviously you’ll no longer be able to get any support. The latter likely won’t faze many in this community, but the inability to repair your Roomba in a few years time might. Then again, depending on what parts we’re talking about, it’s not unreasonable to think that the community could produce alternatives via 3D printing or other methods when the time comes.
A Rich Hacking History
If you’ve been reading Hackaday for awhile, you probably already know that the Roomba is no stranger to hardware hackers. A quick search through the back catalog shows we’ve run nearly 150 articles featuring some variant of the cleaning droid. So it will likely come as no surprise to find that there’s already a number of avenues you can explore should official support collapse.
iRobot invited hacking their robots, we accepted. Image: Fabrizio Branca
To their credit, we should say that the success hackers have had with the Roomba is due in no small part to the relatively open attitude iRobot has had about fiddling around with their product. At least, in the early days.
As Fabrizio Branca mentions in a 2022 write-up about interfacing a Roomba with an ESP32, when he bought the bot in 2016, it even had a sticker that invited the owner to get their hands dirty. While the newer models seem to have deleted the feature, the majority of the older units even include a convenient expansion port that you can tap into for controlling the bot called the Roomba Open Interface (ROI).
So if you’ve got a Roomba with an ROI port — some cursory research seems to indicate they were still included up to the 800 series — there’s plenty of potential for smartening up your vacuum even if the lights go out at iRobot.
With a WiFi-enabled microcontroller riding shotgun, you can fairly easily tie an older Roomba into your home automation system. If Amazon has already taken over your household, you can teach it to respond to Alexa. For those looking to really push the limits of what a vacuum is capable of, you could even strap on a Linux single-board computer and communicate with the bot’s hardware using something like the PyRoombaAdapter Python library.
Solutions for Modern Problems
While this all sounds good so far, we run into something of a paradoxical problem. While the older Roombas are hackable and the community can continue updating and improving them, it’s the newer Roombas that are actually at greater risk should iRobot go under. In fact, many of the Roomba models that support ROI don’t even feature any kind of Internet connectivity to begin with — so they’ll be blissfully unaware should the worst happen.
The options right now for owners of “smarter” Roombas are more limited in a sense, but there’s still a path forward. Projects such as dorita980 and roombapy offer an unofficial API for communicating with many WiFi-enabled Roomba models over the local network, which in turn has allowed for fairly mature Home Assistant integration. You won’t be able to graft your own hardware to these more modern Roombas, but if all you want to do is mimic the functionality that would be lost if the official smartphone application goes down, a software solution will get you there.
It’s also quite possible that the news of iRobot’s troubles might inspire more hackers to take a closer look at the newer Roombas and see if there aren’t a few more rocks that could get turned over. As an example, the Valetudo project aims to free various robotic vacuums of their cloud dependency. It doesn’t currently support any of iRobot’s hardware, but if there were a few sufficiently motivated individuals out there willing to put in the effort, who knows?
A Windfall for Hackers?
In short, folks like us have little to fear should the Roomba Apocalypse come to pass. Between the years of existing projects demonstrating how the older bots can be modified, and the current — and future — software being developed to control the newer Internet-aware Roombas over the local network, we’ve got pretty much all the bases covered.
But for the average consumer who bought a Roomba in the last few years and makes use of the cloud-connected features, that’s another story. There’s frankly a whole lot more of them then there are of us, and they’ll rightfully be pretty pissed off if the fancy new robotic vacuum they just picked up on Black Friday loses a chunk of its promised functionality in a few months.
The end result may be a second-hand market flooded with discounted robots, ripe for the hacking. To be clear, we’re certainly not cheering on the demise of iRobot. But that being said, we’re confident this community will do its part to make sure that any Roombas which find themselves out in the cold come next year are put back to work in some form or another before too long.
15 thoughts on “If IRobot Falls, Hackers Are Ready To Wrangle Roombas
  1. Please fail. Please please please. Please let this lead to some sort of legislation mandating end of life plan for all
    the junk companies and stupid products that need an app and a server back end. Heck I’ll even take the PR to the general public to NOT buy this stuff to begin with.
    Case in point use a regular vacuum and listen to headphones once a week like a grown up. Or like one commenter said buy a shop vac to skirt power use rules. Bigger better cheaper and waterproof.
    Still have zero sympathy for anyone that bought a web server requiring vacuum robot and thought that was a great idea.
  2. They don’t all phone home – I have an older eBay one that doesn’t. OTOH it’s too slow and noisy and gets stuck on wires so I don’t actually use it other than entertaining guests who have never seen one before!
      1. Maybe I had a newer model, but the only time I ever ran into anything like this, it was to keep the thing from getting hung up on a floor lamp’s electrical cord and I was able to use the app to create a small exclusion zone. Worked very well.
        1. This is ultimately the issue. You can either have a local only vacuum robot that is slightly entertaining at best, and a liability at worst. Or you can have a cloud-dependent vacuum that actually does a decent job.
          My Eufy root with lidar mapping does a pretty great job, but disconnect it from the cloud and it’s back to blindly roaming around. There’s no reason for this.
          Hopefully if roomba goes under it creates a market segment someone will fill for a more premium local-only mapping robot.
          We have parrots and having a daily dirt patrol has made a massive improvement in our standard of living! I just hate that I know it’s reliant on servers that WILL go down some day.
  3. “…those millions of domesticated robots…”
    Like, they were feral before?
    But, take off their leashes and they could be feral again. Maybe it’s a good thing the front door threshold will trip them up.
  4. For folks who are not familiar with “corporate hospice care,” there is almost always a process called an “asset sale.” Often there are companies standing in line to offer maintenance services for existing products. So the notion that “phoning home” will soon fail, well, let’s just say it is far too soon to despair.
  5. Other than the initial rush of ‘oh that’s neat’ feelings, why does anyone think these are a good idea?
    Do people live in a clean-room, where a teaspoon of dust accumulates in their entire house every year?
    I have to empty my full sized vacuum every week. It has a volume of almost double the entire Roomba, not just the little dirt tray.
    It is literally less work to do the cleaning yourself than to constantly have to clean out one of those dumb little robot vacuums. And it’s faster too.
    Are people buying them and not using them or something? Because every single person I know that has bought one, has just switched back to cleaning things themselves within a few months and regrets buying it.
    Who are these millions of robot vacuum users?
    1. Many of them have self-emptying compartments in the base station now, so their capacity is closer to a stand-up vac.
      My floors are perpetually grody from cat litter, pine needles, and general “live in the country, it’ll be fun” dirt. Nobody in our house has the surplus capacity to vacuum more than perhaps weekly. If I could spare the cash, I’d drop the money on a self-emptying, self-charging, web-enabled-but-hackable turtle-vac without too much thought.
  6. Absurdly priced sent me to look at other companies offering.
    Found a good one, bought it, happy with it. Price your stuff beyond what people are willing / able to pay and off you go…
  7. Even more ewaste from people who don’t know about hacking these or don’t want to. I’m already planning on how to keep my grandparents from tossing theirs if this comes to pass.
Leave a Reply to BitUniverseCancel reply
