Looking At A Real Fake Raspberry Pi RP2040 Board
Since the RP2040 microcontroller is available as a stand-alone component, it’s easy enough for third parties to churn out their own variations — or outright clones of — the Raspberry Pi Pico. Thus we end up with for example AliExpress sellers offering their own versions that can be significantly cheaper than the genuine article. The ones that [electronupdate] obtained for a test and decapping session cost just $2.25 a pop.
RP2 B0 stepping imprinted on the die shot.
As can be seen in the top image, the board from AliExpress misses the Raspberry Pi logo on the silkscreen for obvious reasons, but otherwise appears to feature an identical component layout. The QSPI Flash IC is marked on the die as BY250156FS, identifying it as a Boya part.
Niggles about flash ROM quality aside, what’s perhaps most interesting about this teardown is what eagle-eyed commentators spotted on the die shot of the RP2040. Although on the MCU the laser markings identify the RP2040 as a B2 stepping, the die clearly identifies it as an ‘RP2 B0’ part, meaning B0 stepping. This can be problematic when you try to use the USB functionality due to hardware USB bugs in the B0 and B1 steppings.
As they say, caveat emptor.
19 thoughts on “Looking At A Real Fake Raspberry Pi RP2040 Board
  1. A question here what the B2 stepping actually looks like under the cap – I don’t know if the layer with “RP2 B0” on it needed to be changed between B0 and B2 – maybe it was a mask ROM only fix? Nobody’s yet published a decap of B2 that I’ve seen. (please prove me wrong in reply!)
    1. Yep. B1 is just a mask ROM change. B2 is a mask ROM change plus a single metal ECO to a counter in the USB controller to make the fatal FSM state drop through following enumeration.
      These are all in the lowest metal/via layers. The layers visible in the photograph (RDL/M7) were not changed so are still labelled B0, because they are the B0 masks.
      1. Also, there are very few B0 devices out in the world. B0 is development silicon that lacks double float support in the ROM, and only around 100k were made (these were just the five “typical” engineering sample wafers). They all went on Picos and pre-launch partner boards. There is no way this is a B0 die.
        You can always check the chip revision from software or the debugger by checking the CHIP_ID register in SYSINFO.
  2. Seems like the clickbait factory bought enough equipment to play at decapping ICs and they were just looking for ICs to decap just like the guys with a hydraulic press are always looking for new things to destroy. Mis-identifying the stepping of the rp2040 is just a footnote to the fact that they didn’t actually intend to characterize the thing at all. If you wanted to know the stepping, or to know if it has a fatal USB flaw, usage would be far more revealing than decapping.
    And the upshot is, raspberry’s intentional policy of releasing the chips cheaply enough that third parties would put them on their own cheap boards has paid off like it was meant to.
          1. Being a board of small size with a RP2040 does not make it a raspberry pi pico as fitting a Ford motor in a car doesn’t make that car a Ford.
            The use of words “Raspberry Pi” and/or logo is allowed under strict conditions.
            Any use of the Raspberry Pi Marks must be accompanied by the acknowledgement “Raspberry Pi is a trademark of Raspberry Pi Ltd”
            The Raspberry Pi Marks must appear less prominently than the product name and your brand/business name
  3. First thing it is on AliExpress. That is first hint about quality. Second actually buying a device from AliExpress and feeding the company that is cloning the Pico boards. Really, the real RPI Pico and Pico 2 boards are dirt cheap. So no need to go looking for clones in the first place. IMHO.
    1. In the video, he said shipping was extremely expensive for the genuine boards in his country.
      I would certainly take my chances with a clone if the shipping cost that much, but one of the approved resellers in the US has free shipping so I will buy from them as long as the boards are in stock.
    2. yeah that’s what i love about rp2040 / pico. i can get ‘the real deal’ for basically the same price as a sketchy knockoff. (i’m in the states and i can’t tell the difference between $4 and $1.27 but i sure can tell the difference between $4 and $25, looking at you ST Micro). rp2040 really is a great product imo
  4. So what is going on with the B0 and B2 stepping?
    I can’t believe that raspberry itself would put B0 dies and then mark the package with B2.
    Did some shady company steal or clone the masks and is making copies of the die or something?
  5. Anyone got part numbers of the two different DCDC converter ICs on the boards?
    I swear I’ve got several variants of the AliExpress boards around here somewhere, but they appear to be in hiding.
    I suppose that’ll be one of the defining differences, along with maybe a dodgy crystal with mismatched load caps.
Leave a Reply to OliverCancel reply
