Project Fail: Cracking A Laptop BIOS Password Using AI
Whenever you buy used computers there is a risk that they come with unpleasant surprises that are not of the insect variant. From Apple hardware that is iCloud-locked with the original owner MIA to PCs that have BIOS passwords, some of these are more severe than others. In the case of BIOS passwords, these tend to be more of an annoyance that’s easily fixed by clearing the CMOS memory, but this isn’t always the case as [Casey Bralla] found with a former student-issued HP ProBook laptop purchased off Facebook Marketplace.
Maybe it’s because HP figured that locking down access to the BIOS is essential on systems that find their way into the hands of bored and enterprising students, but these laptops write the encrypted password and associated settings to a separate Flash memory. Although a master key purportedly exists, HP’s policy here is to replace the system board. Further, while there are some recovery options that do not involve reflashing this Flash memory, they require answers to recovery questions.
This led [Casey] to try brute-force cracking, starting with a Rust-based project on GitHub that promised much but failed to even build. Undeterred, he tasked the Claude AI to write a Python script to do the brute-forcing via the Windows-based HP BIOS utility. The chatbot was also asked to generate multiple lists of unique passwords to try that might be candidates based on some human guesses.
Six months later of near-continuous attempts at nine seconds per try, this method failed to produce a hit, but at least the laptop can still be used, just without BIOS access. This may require [Casey] to work up the courage to do some hardware hacking and erase that pesky UEFI BIOS administrator password, proving at least that apparently it’s fairly good BIOS security.
36 thoughts on “Project Fail: Cracking A Laptop BIOS Password Using AI
  1. Sounds quite complicated compared to say the 90’s, e.g. AMIBIOS, when all you needed was a friend with a similar release, a few reboots to figure out which positions the password was stored in, followed by zeroing of those bytes in the targets bios backup and a quick reboot…all with nothing more than a little patience and some turbo pascal.
      1. But that’s not what the “customer” requested. :-)
        Besides, even if the system had a reset pin, there was nothing to be gained from that other than more work having to reconfigure a bunch of settings the customer didn’t know. It’s beside the point whether or not those values could have been figured out via other means. The difference in time spent was minor and worth the gaining of a skill, at the time at least.
        My comment was aimed at the difference in software based approache given the passage of time vs technology. I was not implying it was the simplest solution to the problem.
  2. I remember looking up how to remove the password on my thinkpad, just to see if it was even possible. It was, but it required me to open it up and dump the bios, send the dump along with $60 to some dude in eastern europe so he can insert an uefi driver that somehow bypasses boot guard, then flash that modified image back so the driver can actually erase the password.
    Meanwhile the average desktop requires just shorting a couple pins.
    1. about 10 years ago i purchased a lenovo T410s (while already owning the non -s version) from ebay with a notice that it had a bios password. after looking up info about it, i learned that the bios password was stored on a different writable rom chip and to bypass the password, this chip would need to be held to reset while the bios was trying to read it, thus making the bios think the password was blank.
      i was able to “blank” password like this and get into bios and then set a new password, save, reboot, back into bios with this new password, then able to successfully clear the bios password altogether.
    1. This is a generic way to bypass any password when BIOS are stored on external chips. You just short the input pin of the chip with ground for a moment while the computer want to acess it and release it after entering in the BIOS (which is empty because the read wasn’t successful). Then you proceed to change the apssword to a known one then you reboot your computer with these changes made.
  3. I’ve read somewhere once (“tell me you have a bad memory without telling me you have a bad memory”) that the aim was to crack a password and the “craker” realized that when the tried password had some correct characters, the reply of being a bad password would take longer than when it didn’t have any good character, maybe that could help or maybe I’m talking rubbish…
    1. It’s the case on non hardened/non-constant time algorithms when you can use side channel analysis (timing attack) to infer if a password (or hash of it) is good or not. It’s kind of rare in the field
    2. That’s been a known attack for a long time. I first read about that problem being discovered and fixed in Unix decades ago. Anything remotely recent and decently done now take pains to equalize decision branches to prevent leaking the password via a “side channel”. I have no doubt it’s still a viable attack for a lot of less fastidiously created stuff out there.
      1. Considering that password checking is simply: “hash entered password” -> “compare result with stored hash” there is very little that can influence timing of that check. Length of the password maybe, but there would be no way of telling what password length is correct. Only way this could work is if the password was stored in plain text, and afaik tha hasn’t been practiced since mid 80’s
    1. I reference that comic all the time, usually when I get “the look” after someone asks for my Wi-Fi password 🤣
      Former favorites:
      rubberbabybuggybumpers
      tallgiraffeseatleaves
      humpbackwhalesarescaredofheights
      lotofheliumtothrowahippo
      Sadly, the best passwords are often unusable, thanks to password length restrictions.
    2. and yet most business including at enterprise level, banks, etc all seem to want us to continue to use combinations of upper, lower, “special character” and number.
      then tell us not to write it down.
      Why on earth is this?
      1. Combination of things. Part of it is regulations (PCI, FBA), and the fact that financial institutions are notoriously late and slow to change and adopt new standards (like for NIST).
        The other part is legacy software or systems that have limits on character length, but more capability re: supporting different character sets. How do you gain security with a max of 12 char? Combinations of upper, lower, number and non-alphanumeric. It’s also (usually) easier to overlay some soft of MFA, and don’t worry as much about shorter, weaker passwords (and work to eliminate SFA.)
    1. Please, point out the instructions to do that on this specific laptop, instead of just “hey you can connect some wires and use some magic code that I assume exists but I’m too lazy to look for”.
      The smart, obvious thing is not to make comments this pointless.
    2. i sure got excited about the confidence with which you used the phrase ‘TSOP clip’. i could see the product in my mind’s eye and i would just love to imagine that it’s cheap and common these days. but google shopping didn’t turn up a hit in the first page of results so :(
  4. So, HP Probooks do have a backdoor for this, but it’s not a “master key” as each laptop requires a unique key file that qualified technicians and partners can request from an engineering team within HP. The process is basically “Put the file on a flash drive, plug it in, turn the laptop on, go into setup and change password.”
    Consumer models (Compaq models, Pavilions, etc.) have a different method that is (mostly) universal but requires nonpublic software.
    Source: Have used both methods at work.
  5. I had a wonderful Toshiba laptop many moons ago that I had to replace the motherboard in.
    The replacement had a locked bios (ugh), but also had a windows control panel that provided access to most of the bios settings. The control panel was also password locked, but the bios API itself wasn’t protected, so patching the binary to bypass the check was all that was needed! I still couldn’t change boot order, but I never ended up needing to.
Leave a Reply to Gilliam VespaCancel reply
