Writing An Open-World Engine For The Nintendo 64
Anyone who has ever played Nintendo 64 games is probably familiar with the ways that large worlds in these games got split up, with many loading zones. Another noticeable aspect is that of the limited drawing distance, which is why even a large open area such as in Ocarina of Time‘s Hyrule Field has many features that limit how far you can actually see, such as hills and a big farming homestead in the center. Yet as [James Lambert] demonstrates in a recent video, it’s actually possible to create an open world on the N64, including large drawing distances.
As explained in the video, the drawing distance is something that the developer controls, and thus may want to restrict to hit certain performance goals. In effect he developer sets where the far clipping plane is set, beyond which items are no longer rendered. Of course, there are issues with just ramping up the distance to the far clipping plane, as the N64 only has a 15-bit Z-buffer, after which you get ‘Z fighting’, where render order becomes an issue as it’s no longer clear what is in front of what.
One fix is to push the near clipping plane further away from the player, but this comes with its own share of issues. Ergo [James] fixed it by doing two render passes: first all the far-away objects with Z-buffer disabled, and then all the nearby objects. These far-away objects can be rendered back-to-front with low level-of-detail (LoD), so this is relatively fast and also saves a lot of RAM, as the N64 is scraping by in this department at the best of times.
In the video the full details of this rendering approach, as well as a new fog rendering method, are explained, with the code and such available on GitHub for those who wish to tinker with it themselves. [James] and friends intend to develop a full game using this engine as well, so that’s definitely something to look forward to.
