Reverse-Engineering An Amazon Blink Gen 3 Camera
After some water intrusion apparently killed one of [electronupdate]’s Amazon Blink Gen 3 cameras he took this opportunity to do a full teardown and analysis of all the major components. Spread across its three PCBs there are no fewer than two wireless ICs and a custom ASIC for all the major processing. There’s also a blog post with easy-to-ogle pictures.
The most basic PCB is effectively just a PCB antenna for the Silicon Labs EZR32 IC on the main PCB, using which the ~915 MHz connection with the central hub is maintained. The other smaller PCB is a bit surprising in that it contains aย Cypress CYW43438 W-Fi b/g/n and BT 5.1 chip. This would seem to be used for the setup process, but considering that it also uses a central hub it is a bit of a mystery as to what it is used for exactly.
Finally, the main PCB contains all the major parts, with the custom Amazon Immedia ASIC that’s an integral part of this very low-power camera. Given that two AA cells being enough to run the camera for about two years, using off-the-shelf parts probably wasn’t good enough without some serious customization.
As for why this outdoors-rated camera failed after a few years in the outdoors, the reason appears to be water intrusion via the speaker opening. As for why a camera needs a speaker and not just the microphone is left as an exercise to the reader, but maybe it could be useful for yelling at the local kids to get off your darn lawn?
12 thoughts on “Reverse-Engineering An Amazon Blink Gen 3 Camera
    1. So I can monitor my house when I’m not there. The fact these are battery powered limits their pervasive surveillance risk, but even so: I’m aware of the intrusion and I don’t care because of the benefit it provides me.
  1. Wonder what the state of the art for ultra low power video processing/streaming is, all those chips in there were from the first half of last decade with impressive performance.
    1. Yes I wonder that as well. I design low power IIoT devices for a living, many working in ATEX conditions but I have never ever heard “ultra low power” and “video processing/streaming” together in a single sentence
  2. I’ve been given two of these cameras by a friend’s relative, but they forgot the hub and I didn’t know at the time. I wanted to use one to monitor my 3D printer, but then I found out that they don’t simply connect to wifi, so I’m hoping that some effort will be made to turn them into something useful and standalone through custom firmware!
    1. You are not likely to put custom firmware on them. They use a proprietary ASIC that does the video processing. Even if you cracked the secure boot, you’d need the compiler and datasheet to get working firmware.
      Source: I worked at Blink for 5 years. They started as an ultra-low power video processing ASCI company (Immedia Semiconductor) and pivoted to battery powered cameras. The heart of the camera is a custom chip running custom firmware.
      The hubs can be purchased and paired with the any camera, but the cameras will have had to been deleted from the original account.
Leave a Reply to mcenderdragonCancel reply
