We’ll start things off this week with a story that’s developing more than 25 billion kilometers from Earth — on Friday, NASA announced that the command had been sent to shut down Voyager 1’s Low-energy Charged Particles (LECP) instrument. As the power produced by the spacecraft’s aging radioisotope thermoelectric generator (RTG) continues to dwindle, engineers at the Jet Propulsion Laboratory have been systematically turning off various systems to extend the mission for as long as possible. It’s believed that deactivating LECP should buy them another year, during which engineers hope to implement a more ambitious power-saving routine. If this sounds a bit familiar, you’re probably thinking of Voyager 2. The plug was pulled on its LECP instrument back in March of 2025.
The JPL engineers hope that their new plan may allow them to reactivate previously disabled systems on the twin space probes, but even if everything goes according to plan, there’s no fighting the inevitable. At some point, there simply won’t be enough juice in the RTGs to keep the lights on. Although it’s going to be a sad day when we have to bring you that news, surviving a half-century in space is one hell of a run.
Speaking of ending a run, just a week after Amazon announced that pre-2012 Kindles would no longer be supported, the company is letting users know that the Kindle software for PCs will be discontinued in June. In its current form, at least. As Good e-Reader reports, Amazon is developing a new client for users who want to access the Kindle ecosystem from their computers, but it will only run on Windows 11. Since older software could be used to strip DRM from purchased ebooks, it seems likely this is another attempt to lock the platform down.
We’re not fans of arbitrary limits being placed on ebooks and the devices that read them, but on the other hand, there are definitely systems out there that could stand to be tightened up a bit. For example, research out of Quarkslab has shown that the electronic control unit (ECU) from a wrecked vehicle can reveal a surprising amount of information.
After picking up a used ECU, they were able to dump its NAND flash chip and decode the log files it contained. It turns out the car had GPS logs going back to the day it rolled off the assembly line, and the researchers were able to reconstruct every trip it ever made.
By cross-referencing the last recorded coordinates with social media posts, they were even able to find pictures of the crash that took the vehicle out of commission. It’s bad enough that personal information can be scraped off of secondhand hard drives; now we’ve got to worry about what happens to our cars after they get hauled off to the junkyard.
If these are the sort of stories that keep you on two wheels rather than four, you may be interested in the latest innovation from Škoda Auto. In an effort to reduce collisions with pedestrians, they’ve developed a bike bell that penetrates active noise cancellation (ANC) systems. The logic goes like this: if someone is walking around with headphones that feature ANC, they might not hear the bell of an approaching bike. So they teamed up with researchers from the University of Salford to essentially find the weaknesses in existing ANC systems.
As you might have guessed, irregular noises are harder to block out than constant tones. Researchers uncovered a gap between 750 and 780 Hz where sounds could sneak through. The mechanical bell uses both principles to defeat ANC, and in testing, it was shown to provide headphone-wearing pedestrians more time to react to an approaching bicycle.
Finally, we’ll bring this week’s post full circle by starting and ending on a space story: earlier this week, PBS released the hour-long documentary Artemis II: Return to the Moon on YouTube. Watching PBS programming on YouTube might seem a bit odd, but that’s the world we live in these days. At any rate, the video is a fascinating look into what went into the recently concluded Moon mission and has us even more excited for Artemis III and beyond.
See something interesting that you think would be a good fit for our weekly Links column? Drop us a line, we’d love to hear about it.
Sadly vidoe is not avsilable in my country…..
also region locked on pbs.org :(
https://www.torproject.org/ (in torrc: ExitNodes {US})
Voyager’s 1970’s tech was robust.
Even single electrons can damage chips
https://phys.org/news/2026-04-quantum-electrons-silicon-chips.html
In space, there is no cheap
https://forum.cosmoquest.org/forum/cosmoquest-and-friends/universe-today/3753397-why-nasa%E2%80%99s-cheapest-missions-produce-the-least-science
The LECP shutdown wasn’t planned, though – there was an unexpected power drop during a roll maneuver, and so the LECP shutdown is preventative to ensure that the spacecraft doesn’t undervolt and trigger forced onboard procedures which might not work.
“during which engineers hope to implement a more ambitious power-saving routine.”
Both the Voyagers have a number of instruments/devices which are just remaining powered as heaters to keep the spacecraft warm enough to function. The idea here (which they cutely call the ‘Big Bang’) is to swap out the current set of devices with another set of devices which would be lower in total power (but enough to keep the spacecraft warm). That difference might be enough to turn some instruments back on.
In layman’s terms, they’re saving power by turning the house thermostat down a bit.
