How Britain Narrowly Escaped A Grid Blackout In June 2026
Amidst one of the worst heatwaves in European history, Britain’s national grid saw itself faced with a quiet crisis this summer. On June 23rd, the grid frequency dropped to 49.657 Hz, down from the nominal 50 Hz — getting very close to the lower bound before safeties would start disconnecting parts of the grid. In a video by [The Electric Brit] this event is investigated, including its causes and how France’s spare capacity managed to save the day.
Under normal operating conditions the UK grid is kept above 49.8 Hz, with the statutory lower limit being 49.5. Meaning that another drop of 0.157 Hz would have set in motion a series of quite extreme grid protection mechanisms including the possibility of local blackouts.
Fortunately the cessation of energy exports and the importing of French power from hydro and nuclear power stations managed to nip this issue in the bud before it could get any worse. Although an example of correct grid management, it also shows how poorly planned maintenance and events like a heatwave can line up quite a few holes in the cheese slices that invite disaster.
The problems here began weeks prior to the event, with 21.2 GW of generating capacity offline. Of this, 12.6 GW was planned maintenance, another 8.6 GW was unexpectedly offline, while another 2.6 GW of gas generation was mostly unavailable due to the heatwave curtailing production. A couple of interconnections with Ireland and other nations were also down for maintenance, leaving the grid control room with precious few options.
Although the UK’s transmission system operator (TSO) NESO had its predicted capacities for variable renewable sources (VRE) like solar, it could not see local demand and production from e.g. rooftop solar in the control room. This became rather exciting when the evening neared and rooftop solar output dropped. Here NESO turned out to be lucky, but such hidden factors form a major risk factor when such consumers return to grid power.
As VRE sources fell quiet across Europe that evening, this put the onus on remaining generating sources and brought the slowly developing crisis to its apex. Fortunately importing energy from France saved the day here, but there are many lessons to be learned here, many grounded in how complex AC grid management is once you consider all aspects that affect not just generators but also transmission lines.
This event is different from the frequency oscillations that triggered the blackout on the Iberian peninsula in 2025. In that case a problem existed with reactive power management, with oscillations amplified by grid-following converters from solar farms and insufficient capacity on the grid to absorb this surge in reactive power, ultimately leading to the cascading blackout.
Amidst these lessons on grid-management the discussions on whether baseload power generating is truly dead among other tropes, as well as the calls by European TSOs to make grid-forming converters mandatory on VRE generators will no doubt intensify.
16 thoughts on “How Britain Narrowly Escaped A Grid Blackout In June 2026”
  1. One does wonder if more storage would have mitigated some of the effects?
    “…with oscillations amplified by grid-following converters from solar farms …” An interesting failure mode most likely not in the brochures.
    1. One challenge addressing the Iberian peninsula blackout was no one quite wants to admit the fault.
      It’s easy to say that reactive power management needs to do better, it’s harder to admit an unstable system is hard to manage.
      Grid forming solar is available but as per usual that would require proactive planning or foresight no one has until something goes wrong.
      Still it’s neat to think that literal spinning mass in synchronized systems genuinely provides something hard to replace or drop.
    2. Solar has given us nigh unlimited energy but we won’t use it because some marketing genius convinced people that expensive LiFePO4 is the only chemistry of worth to be used with your hybrid inverter/off-grid inverter or worse for large BESS/BEGS systems. Most people wouldn’t mind having a container sized lead acid or pumped electrolyte battery in their basement or anywhere on their property, if they can be off grid, but somehow we magically never see this.
      Imagine it rains meatballs everyday for hours at an end but you only grab one and eat it for lunch and then you spend every night still going to bed hungry because you didn’t save another one for later. That is us here.
      Solar is not at fault, its the utility companies that take the worst possible decisions to persecute solar users instead of actually building resilience. The reasonably fair net metering world has come to an end, and the unfair net billing world is upon us. I get why they’re doing it however
      1. Seriously? Have you done the arithmetic? What’s the ROI or payback period for a solar field and battery storage system capable of powering just one house and one electric car for all their annual energy needs? How much area will that take, and how much cropland will that remove from food production?
        I’m all for solar (to displace peak air conditioning loads), and for battery storage (for grid stability and peak shaving). But to suggest solar is the only source, that it is “unlimited”, or that batteries of any type will get a city through a typical December, is a fever dream.
        1. It’ll depend heavily on the household and the country. I’ve got 5 solar panels on a fence, so a footprint close to nothing and they generated 1MWh this year vs my grid import of 4MWh. I could probably get that up to 40 or 50% coverage if I added panels on the roof which wouldn’t consume extra land.
          Now if you were going to displace anything start with biofuel crops which are inefficient, then go through inefficient processing, only to get burned inefficiently.
      2. If I owned a farm or similar plot of land I would consider filling an out-building with Nickle Iron batteries. Yes, they are expensive and yes they have a lot of disadvantages. But… my great great grandchildren could still be using them and all that would be required is occasional top-offs with water and maybe a twice-per-lifetime electrolyte swap. I would just start with a small collection and build the battery bank up over time as funds allow.
        1. Do you really need that implied capacity is the question – seems like for most folks own use at least that small bit of real estate you can find space for even in a small house, maybe even in an apartment is enough. Even the worst energy density so bulkiest battery packs when wardrobe to maybe large double wardrobe side sized are likely sufficient unless you wish to enter the energy trading game.
  2. Australia has a larger and more complex grid that is subject to far higher temperatures, this leads me to conclude that those factors are less relevant than suggested and that there is some issue with competence at the heart of the spate grid failures in the EU and UK. Australia does have regular localised failures but they are usually in response to storms or other natural disasters on a scale never seen in the UK, the overall system itself seems more robust, or better managed.
    1. Australia doesn’t have a National Grid. Hell, even the nominal voltage isn’t equal everywhere (240V nominal in Perth,WA, 230V in the rest of the country).
      And there is no interconnect between Perth and the rest of the country, there is a 1000km wide zone with only scattered local grids, usually based on a combination of Solar, Wind, Batteries and Diesel generation.
      And in the three years I’ve lived in Perth I’ve had more power outages (about 2 per year) than during 30 years in the Netherlands (about 1 every 10 years)
  3. Their government has only just told them to stock up for 3 days. Funny that as it wasn’t long ago they were demonizing preppers.
