A Bike-Friendly, DIY Action Cam Stereo Microphone
[DJJules] had two problems. Being an avid biker, recording audio on a bike-mounted action camera was less than ideal due to wind. In addition, the built-in microphone on action cameras is also just not as good as a dedicated stereo microphone setup. His solution: The Bike Mike.
The furry ends contain one mic each, mounted with foam.
The Bike Mike solves both problems at once by providing a windproof stereo microphone for [DJJules]’s bike-mounted action camera. It consists of a 3D printed frame and mount for two electret microphones. The mics each get a foam cover, and are surrounded by a cage upon which furry mic covers are applied.
The microphones are wired up to a 3.5 mm audio connector, which is a pretty straightforward soldering job. To make it compatible with the action camera, [DJJules] uses a super slim USB microphone adapter that accepts the 3.5 mm connector on one end, and provides a USB-C plug on the other. One can insert that directly into the camera and have it recognized as an external mic.
If this looks a bit familiar, it’s similar to his earlier design for a DIY external stereo mic for things like DSLR cameras. This one’s adapted for action cameras, integrating a USB adapter for a wider compatibility.
Embedded is a build video followed by sample footage, so give it a watch and listen for yourself.
One thought on “A Bike-Friendly, DIY Action Cam Stereo Microphone”
  1. Later on in the video I catch that I’ve got the channels reversed so I switch around . Still at the beginning I can’t correlate what I’m hearing with seeing, there didn’t seem voice only in one channel when talking into the end of one mic.
    I have been experimenting with desktop speaker grille which has fine holes in metal. When covering my ears it kills wind noise so bare headphone elements can sit inside of the turbulent outside. No foam or felt to deaden sound either in the phones or outside. No headband either, there is a spring band from the rear. Just the cup mounts to a headband make wind noise. The best of both, no “cup sound” and biking safety aware. The best headphones I’ve ever had.
    I’ve thought of mics as well both for biking video and hearing enhancement at the 3K hearing loss I have due to a one farad cap exploding too close.
