High-Power LED + 3D Printer = Mega Flashlight
If you remember old computer magazines (or browse them today), you’ll see that back in the late 1970s and early 1980s, you weren’t always sure what you were going to do with a computer. Games were a staple, but they weren’t very exciting. Visionaries talked about storing recipes, writing Christmas letters (to send via snail mail), and keeping home inventories. You probably don’t do any of those things with your computer today, unless you count e-mailing instead of sending Christmas cards. We think sometimes 3D printers fall into that category today. Sure, you want one. But what are you really going to do with it? Print keychains?
That’s why we always like seeing practical designs for 3D printed items. Like this 100W flashlight. The electronics part of the build is simple enough: a 100W LED module, an off-the-shelf driver board, plus an old PC cooler and some batteries. But the 3D printed parts makes it all come together and it looks great!
Continue reading “High-Power LED + 3D Printer = Mega Flashlight”
Monster 100W LED Flashlight Produces A Whopping 8500lm!
100W LED Flashlight
[Yannick] got a hold of a 100W LED diode recently, and like any self-respecting hacker, he just had to turn it into a ridiculously over powered flash light.
The tricky thing about these diodes is that they need a high amount of DC voltage, anywhere from 32-48V typically. [Yannick’s] using a 12V sealed lead acid battery coupled with a 600W constant current boost converter which ups it to 32V at around 3.2A. He also managed to find a giant aluminum heat-sink to keep the diode from getting too hot. A 120mm fan helps to keep the heat sink nice and cool, which allows the light to be run constantly without fear of burning it out. But just in case he also has an Arduino monitoring the temperatures — oh and it provides PWM control to adjust the brightness of the light!
To focus the flashlight he bought a proper lens and reflector which can be mounted directly to the diode. At full power the LED puts out around 8500lm, which is brighter than almost all consumer projectors available — or even the high beams of a car!
Continue reading “Monster 100W LED Flashlight Produces A Whopping 8500lm!”
Monster 100W LED Flashlight For Under $10!
What would you do if you came across a 100W, 7500 lumen LED diode for under $10? Probably something like this.
It’s actually quite amazing how cheap LEDs are getting. [Julian Ilett] found this 2″ x 2″ LED on eBay for only £4.79 (<$10 USD). It’s rated for 32-34V with a current draw of 3000mA, which works out to about 100W. Its brightness? 7500 lumens. That’s brighter than most home theater setups.
At that price, [Julian] had to try playing with one. The problem with these higher power LEDs is that they typically need a rather expensive LED driver, due to the less common voltages they operate at — and of course, the concern of over-driving them and burning them out. Not interested in finding a suitable driver, [Julian] decided to try something a bit less conventional — wiring a pair of 18V drill batteries in series.
Continue reading “Monster 100W LED Flashlight For Under $10!”
