[Reza] sent in his mood rock. Unlike other “mood” devices, instead of showing what mood you’re in, it shows what mood the internets are in. Two ShiftBrite modules are controlled by an AVR ATmega8 which then connects to a computer via USB. The assembly is placed inside of a piece of alabaster.
USB communications are controlled by the ATmega8 running V-USB (formerly AVR-USB) firmware. [Reza] wrote some code to control the colors from the web using Perl and AJAX. Head over to the web interface to set the colors yourself. We’d love it if a live webcam was added so we could see our mood on the rock itself. Continue reading “Web Controlled Dark Crystal”
