Sleeping Rough In Alaska With A USPS Cargo Bike
Out of all 49 beautiful US states (plus New Jersey), the one you’d probably least want to camp outside in during the winter is arguably Alaska. If you were to spend a night camping out in the Alaskan winter, your first choice of shelter almost certainly wouldn’t be a USPS electric cargo trike, but over on YouTube [Matt Spears] shows that it’s not that hard to make a lovely little camper out of the mail bike.
We’re not sure how much use these sorts of cargo trikes get in Alaska, but [Matt] seems to have acquired this one surplus after an entirely-predictable crash took one of the mirrors off. A delta configuration trike — single wheel in front — is tippy at the best of times, but the high center of gravity you’d get from a loading the rear with mail just makes it worse. That evidently did not deter the United States Postal Service, and it didn’t deter [Matt] either.
His conversion is rather minimal: to turn the cargo compartment into a camper, he only adds a few lights, a latch on the inside of the rear door, and a wood-burning stove for heat. Rather than have heavy insulation shrink the already-small cargo compartment, [Matt] opts to insulate himself with a pile of warm sleeping bags. Some zip-tie tire chains even let him get the bike moving (slowly) in a winter storm that he claims got his truck stuck.
While it might not be a practical winter vehicle, at least on un-plowed mountain roads, starting with an electric-assist cargo trike Uncle Sam already paid for represented a huge cost and time savings vs starting from scratch like this teardrop bike camper we featured a while back. While not as luxurious, it seems more practical for off-roading than another electric RV we’ve seen.
Continue reading “Sleeping Rough In Alaska With A USPS Cargo Bike”
A blue work tricycle (single front wheel with platform between two rear wheels) sits on an asphalt path with trees and wildflowers in the background. A boxy, white camper with a front overhanging the bike seat is attached to the platform. It has a yellow stripe and curtains like many campers did in the 1970s. One white male is exiting the door of the camper while his brother is standing to the left of the camper by the bike seat.
Bike Camper With Retro Flair
As we’re approaching summer here in the Northern Hemisphere, thoughts naturally turn toward road trips. While most people do this in their car, the [Dangie Bros] built a 500 lb bike camper for their own take on the great American Road Trip.
Taking a maximalist approach not seen in most bike campers, this behemoth has a working sink, propane stove, seating area, and an upstairs sleeping area. A small window in the front of the camper opens to let the passenger inside converse with the person pedaling, and a solar panel charges a small battery for lights and a roof fan.
While the camper is very ’70s retro-chic, its lack of assist (other than the passenger getting out to push) meant that on the second day of their road trip they resorted to towing the camper behind a second bike in a pseudo-tandem arrangement. The fold out bed takes some design cues from RVs, but clearly needed more reinforcement since it collapsed partway through the night. With an e-assist and some refinements, this could be comfortable (albeit slow) way to go bike glamping.
If you’d like to try your own hand at a bike camper but do it more aerodynamically and attached to an assisted bike, checkout this teardrop trailer or this bike camper.
Continue reading “Bike Camper With Retro Flair”
Custom Cycling Camper Continues Car-Free
If you own a camper or RV, you might think twice when taking it out after giving gasoline prices a look. Towing all that extra weight and wind drag along can really eat into your fuel efficiency. [Drew] decided to keep the camper but take gasoline out of the equation by building a teardrop trailer he pulls behind his bike.
It’s a relatively simple idea. A 1″ by 1″ steel tube frame makes up the bottom, which [Drew] welded together. On top of that, plywood walls were built up over a plywood base. The wheels were stolen from an older bicycle and the top was made with many bending techniques using a portable fabric steamer for clothing. [Drew] found used doors and windows right in his backyard, which helped lower the cost. The trailer is insulated with sheet foam because it’s cheap and easy to cut.
In addition to the creativity, there’s a big focus on waterproofing and durability throughout this build. [Drew] applied caulk to the threads of every screw to prevent water from getting in and rotting the plywood. Canvas was used instead of fiberglass to save cost as it provides a fairly high level of protection from rain when finished properly. Cheap LEDs and a USB battery pack created stylish and functional lighting inside.
Overall, we think it turned out quite well, and we would love to bike somewhere and camp out in our own teardrop trailer. It’s a gorgeous example of welding, woodworking, and some plain ingenuity in the face of adversity. We’ve seen solar-powered trailers for e-bikes and campers for custom motorcycles before, and we think [Drew]’s trailer would fit right in. Video after the break.
Continue reading “Custom Cycling Camper Continues Car-Free”
