Thumb Nuts For Not A Lot
Sometimes it’s the most straightforward of hacks which are also the most satisfying, and so it is that we’d like to draw your attention to [mikeandmertle]’s PVC thumb nuts. They provide a cheap an easy to make way to create thumb-tightenable nuts for your projects.
Starting with a PVC sheet, a series of discs can be cut from it with a hole saw. The hole in the centre of the disc is chosen such that it’s a bit smaller than the required nut, so that it can be pressed into the space with a bolt and a washer. Then a second PVC disc is glued over one side of the first before being sanded to a regular shape, resulting in a captive nut at the centre of a finger-sized and easily turnable handle.
We like this project, and we think that quite a few of you will too. We wonder how much torque it will take, but we’re guessing that a threaded insert could easily be substituted for the nut in more demanding applications. And of course, for more demanding applications you could always try knurling.
