Flying A Normally-Sized Drone With A Nano-Drone’s Brain
Drones come in all shapes and size, and [Kedar Nimbalkar] was wondering if the guts of a tiny Cheerson CX-10 nano-drone could take off with a larger body, leading to an interesting brain transplant experiment.
For his test, [Kedar] acquired a CX-10 and the body of a larger Syma X5SW drone. After gutting the CX-10 for its LiPo battery and circuit board, which features an STM32 ARM-core MCU, a 6-axis IMU and the wireless transmitter, [Kedar] studied the datasheet of the onboard SQ2310ES driver MOSFETs. He figured that with a maximum continuous current rating of 6A, they would probably be able to cope with the higher load of the slightly larger motors of the X5SW body. They also didn’t seem to overheat, so he just installed the board into the new body as-is and wired up the motors.
Continue reading “Flying A Normally-Sized Drone With A Nano-Drone’s Brain” →
