Have you always wished that you could develop games for the Super Nintendo but couldn’t because you were only 4 years old when it was released in 1990? Here’s a second chance. [Max] and his team have created a SNES developer’s cartridge that allows you to load your own code, run it on the SNES, and debug as needed. At its core is an Atmel AVR ATmega644 that is running a boot loader, allowing for firmware updates via USB. Once the system is powered on, ROM code is sent over USB to the 16 megabits of onboard SRAM. A debug terminal can be connected with an RS232 converter, providing status information and allowing some register manipulation.
We can believe there are a few hardcore SNES fans out there who will take the time to write custom code. We could also see this being used for the purposes of SNES sythesized music. But is there a wide demand for this type of hardware? If you’ve ever looked into developing for the SNES, let us know in the comments.
