It’s one thing to mount a big skull—human or animal—to the front of your car. Really, though, a good hood skull should breathe fire to truly inspire enmity or awe. Thankfully, when [Anthony] went about modifying his ex-school bus, he was sure to equip it with suitably flaming equipment. It’s dangerous, so don’t try this one at home and melt your car, you hear?
The build started with an off-the-shelf replica cow skull, in lovely flame-resistant metal. It was then plumbed with a propane feed that could be triggered by a 12-volt solenoid. This was combined with a high-voltage coil driving a grill igniter to provide the necessary initiating spark.
To go forth with flames, first, a missile switch must be flipped up and engaged to arm the system. Then, hitting the skull-and-crossbones button will send fire surging forth from the front of the vehicle.
Alternatively, a wireless keyfob can be used, which bypasses the arming system—so leaving the remote in a pocket is ill-advised.
Amazingly, a former project posted on Hackaday served as an inspiration for this build.
Continue reading “Flaming Skull Hood Ornament Is Not Suitable For Use In Traffic”
