Traditional joysticks typically use potentiometers or hall effect sensors to determine the displacement of the stick itself when moved by the operator. Force-sensing joysticks are considered more desirable for certain purposes like side-stick flight simulators, because they measure the force applied instead, as per the name. They can be expensive to buy off-the-shelf, but you can build a cheap set on your own if you know what you’re doing, as [tekasza] demonstrates.
The build that [tekasza] put together is based around the Teensy 4.0 microcontroller. It’s set up to read a series of load cells that determine the force applied to the stick in the X and Y axes. The cells are wired up to HX711 load cell amplifiers so they can be easily read by the microcontroller. The Teensy does the work to take the load cell readings and convert them into axis outputs for a USB HID game controller, allowing the stick to be used with just about any game or simulator on the market. [tekasza] has the stick integrated with pedals as well as a whole bunch of buttons and switches to control other simulator features, built up into a full seated sim setup.
If you’ve ever wanted to use a force-sensitive stick like modern fighter pilots do, this build could be very relevant to your interests. We’ve also seen plenty of other great sim hardware builds in recent years, too.
Continue reading “DIY Force Sensing Joysticks Are A Cheap Way To Go”
