The secret to domestic bliss often lies in attention to detail, an area in which we can all do a little better. But if paper notes and smartphone reminders are not enough to help you remember to knock jobs off your list, perhaps this IoT task reminder will give you the edge you need to keep the peace at home.
As [Andreas Spiess] points out, his best intentions of scheduling recurring tasks in Google Calendar were not enough to keep him on on top of his share of chores around the house. He found that the notifications popping up on his phone were far too easy to swipe away in favor of other distractions, so he set about building a real-world reminder. His solution uses a WeMOS D1 Mini in a bright blue 3D-printed box with from one to four LED switches on the front. Each box is linked to his Google Calendar, and when a task comes due, its light turns on. Sprinkled about the house near the task, like the laundry room or near the recycling, [Andreas] can’t help but see the reminder, which only goes out when he cancels it by pressing the task button. Simple but effective, and full of potential for other uses too.
Of course, the same thing could be accomplished with a Magic Mirror build, which we’ve seen a lot of over the years. But there’s something about the simplicity of these devices and their proximity to the task that makes sense — sort of like the Amazon Dash concept. We might build a few of these too.
Continue reading “IoT Chore Reminder For The Serially Forgetful”
