Don’t forget to get your connected device entered in the Hackaday Prize by Monday morning. The current challenge is IuT ! IoT, a clever tilt at the Internet of Things, which is so hot right now. We don’t just want things to connect, we want that connection to be useful, so save your Internet Toasters and Twittering Toilets for another round.
So what are we looking for here? Any device that communicates with something else and thereby performs a service that has meaningful value. The Hackaday Prize is about building something that matters.
We’ve been covering a lot of great entries. HeartyPatch is an open source heart rate monitor and ECG that communicates through a smart phone. We’ve seen an affordable water level measuring station to help track when water levels are rising dangerously fast in flood prone areas. And the heads-up display for multimeters seeks to make work safer for those dealing with high voltages. Get inspired by all of the IuT ! IoT entries.
There’s $20,000 at stake in this challenge alone, as twenty IuT projects will be named finalists, awarded $1000 each, and move on to compete for the top prizes in the finals.
If you don’t have your project up on Hackaday.io yet, now’s the time. Once your project is published, entering is as easy as using the dropdown box on the left sidebar of your project page. [Shulie] even put together a quick video showing how to submit your entry. Check to make sure “Internet of Useful Things” is listed on your project’s sidebar and if not, use that dropdown to add it.
