Do you enjoy drinking juice but hate the cleanup after making it? Yeah, we do too. So does [Max Maker], which led to the design and birth of the $40 cold-press juicer. If you’ve been thinking about buying a juicer but the cost has been keeping you from pulling the trigger, you should definitely check it out. This build will save you some serious cash and looks relatively simple to replicate.
[Max] designed this juice press while keeping us common folk in mind who don’t have expensive tools in our humble garage or workshop. For example, to make the tray, we are shown how to perform the initial bends in the sheet of stainless steel using only some plywood and clamps. Then we’re shown how to bend the corners, and finally the ‘funnel’ part of the tray with just a few more basic tools – a bench vise, hammer, and pliers. No metal brake required!
The press is easy to use – wrap your fruit or vegetables in some cheesecloth, put it on the tray, and pump the handle of the jack. Clean-up (which has been a notorious pain-in-the-rear when it comes to commercial juicers) is quick and simple too – just rinse the tray!
Build video after the break.
Continue reading “A Cold Press Juicer For The Price Of A Few Trips To Jamba Juice”
