Do you remember the magnetic card spoofer in Terminator 2? It was a bit farfetched because apparently the device could be swiped through a reader and magically come up with working account numbers and pin numbers. We’re getting close to that kind of magic with [Jaroslaw’s] card spoofer that is button-programmable.
Building off of a project that allows spoofing via an iPod and electromagnet, [Jaroslaw] wanted something that doesn’t require a computer to put together the card code. He accomplished this by interfacing a 16-button keyboard and a character LCD with an AVR ATmega168 microcontroller. Card codes can be entered with the buttons and verified on the LCD. Of course this is still dependent on you knowing the code in the first place.
As you know, credit cards use this technology. We don’t think Walmart is going to be OK with you pulling this out in the checkout line, not to mention local five-oh. This technology is also used for building access in Universities, businesses, and hotels. If used in conjunction with some other spy technology you’ll be on your way to becoming a secret-agent-man.
