Sometimes, a little goes a long way. I believe that’s the case with this tiny media control bar from [likeablob] that uses an ESP32-C3 Super Mini.
And because it uses this Wi-Fi-enabled microcontroller, it can seamlessly integrate with Home Assistant via ESPHome.
What else is under the hood? Four low-profile Cherry MX Browns and a rotary encoder underneath that nicely-printed knob.
If you want to build one of these for yourself, all the files are available on GitHub including the customizable enclosure which [likeablob] designed with OpenSCAD. Continue reading “Keebin’ With Kristina: The One With The MingKwai Typewriter”
