kaleidoscope
Arduino Powered Digital Kaleidoscope
[Jose’s] latest project brings an old visual effect toy up to date with digital electronics. Most of us are familiar with inexpensive kaleidoscope toys. Some of us have even built cheap versions of them with paper tubes, mirrors, and beads. [Jose] wanted to try to recreate the colorful pattern effects created by a kaleidoscope using an Arduino and an addressable LED strip.
The build is actually pretty simple. The base is a disc of PVC cut to just a few inches in diameter. [Jose] started with an addressable LED strip containing 60 LEDs. He then cut it into 12 sections, each containing five LEDs. The smaller strips were then mounted to the disc, similar to spokes on a bicycle wheel. The LED strip already has an adhesive backing, so that part was trivial.
The final step was to add some kind of diffuser screen. The LED strips on their own are not all that interesting. The diffuser allows the light to blend together, forming interesting patterns that are more reminiscent of the patterns you might see in a real kaleidoscope. Without the diffuser you would just see individual points of light, rather than blended color patterns.
The whole thing is controlled by a small Arduino. [Jose] has made the code available at the bottom of his blog post. Be sure to watch the video of the system in action below. Continue reading “Arduino Powered Digital Kaleidoscope” →
These Trackpad Winamp Visualizations Really Whip The Llama’s Ass
As much as we like a good clean Model M specimen, those curly-corded clicky behemoths are somewhat lacking for certain flavors of gaming. There aren’t any blank keys to override, and there sure isn’t a full-color trackpad that you can write apps for. [Gus] has such a keyboard: the Razer Deathstalker Ultimate which features the SwitchBlade UI. He made himself this sweet audio visualizer for it that extends Winamp visualizations to the Switchblade UI.
[Gus]’s hack is built on the Tiny3D visualization framework. It does what you might expect—reads the visualization values, sets them up for display on the trackpad, and renders them to said trackpad. [Gus] uses some of the 10 programmable keys to change colors on the fly, and the result is pretty awesome. As [Gus] points out, this is just the beginning of what the plugin can do. You’ll need the Razer SDK to get started, and you can get the other ingredients from [Gus]’s repo. Once you’re done with this, you could try auto-dimming your keyboard backlight.
Of course there are demo videos after the jump. Come on.
Continue reading “These Trackpad Winamp Visualizations Really Whip The Llama’s Ass” →
