A strange thought yes, but MIT researchers think an extra two digits could really make a difference in many people’s lives. And as it turns out, having an extra robotic grasp allows you to do quite a few things single handed.
The extra two fingers provide three degrees of freedom each, and are mounted off the user’s wrist. A series of position recording sensors attached to the glove provide feedback to the system in order to control the fingers naturally, just by using your hand normally.
They taught the algorithm that controls the fingers by trying to pick up different (large) items using the hand and manually positioning the fingers. What they discovered is almost every grasp could be demonstrated as a combination of only 2-3 grip patterns. Continue reading “What Could You Do With 7 Fingers?”
