GlowBlaster Uses 405 Nm Laser To Make Its Mark
Ever wish you could do a little target shooting in a galaxy far, far away? Well then you’re in luck, as the Star Wars inspired GlowBlaster designed by [Louis Abbott] can help you realize those dreams with a real-life laser pistol — albeit a much weaker one than you’d want to carry into a Mos Eisley cantina.
Inside the 3D printed frame of the GlowBlaster is a 5 mW 405 nm module, an Arduino Nano, a speaker, a vibration motor, and a 9 V battery. When you pull the trigger, it pushes down on a 12 mm tactile button which causes the Arduino to fire the laser and sprinkle in a bit of theatrics by way of the speaker and vibration motor. There’s also a second button on the side of the blaster that lets you pick between firing modes.
Continue reading “GlowBlaster Uses 405 Nm Laser To Make Its Mark”
Node-RED Laser Shooting Gallery Goes Anywhere
When you think of a shooting gallery, you might envision a line of tin cans set up along a split-rail fence, or a few rows of ducks or bottles lined up at a carnival. But what do these have in common? You, standing in one spot, and shooting in the same general direction. You’re exposed! If those targets could shoot back, you’d be dead within seconds. Wouldn’t it be more fun if the targets were all around you in 360°? We think so, too.
So how could you possibly set up a shooting gallery this way? [Another Maker] already solved that problem for you with ESP32s and Node-RED (YouTube). Each target has an ESP32, a laser sensor, and an LED that lights up when the target is ready, and turns off once it’s been hit. They all make an enticing ‘shoot me’ sound that goes with their graphics, and a second mp3 plays upon direct hit.
The PVC gun houses an ESP8266, a laser module at the end of the barrel, and runs on a cylindrical USB battery slipped down in the secondary grip. [Another Maker] can spread the targets out far and wide, as long as they all stay in range of the localized WiFi access point.
The best part is that the Node-RED system is target-agnostic — it doesn’t care how many you have or how they’re made, and it can juggle up to 250 of them. Because of the way the target objects are programmed, it would be quite easy to add actuators that make them drop down or fall backward when hit. You could also implement [Another Maker]’s fantastic suggestion of hitting arcade buttons with NERF darts instead. Charge those lasers and fire at the break button to see the demo and walk-through video.
If you plan to knock the targets down or over in your implementation, you’ll want an easy way to reset them. Here’s a scrap-built shooting gallery that uses a windshield wiper motor to set ’em back up.
Laser Shooting Gallery Made From Scrap
When he’s not being completely awesome hosting a radio show on electronic music, [Gaston Klares] is busy in his workshop coming up with some awesome stuff. One of his most recent builds is a laser gun shooting gallery that brings a classic carnival game to his back yard. (Google translate link)
The laser gun itself is made up of 95% recycled components. The purpose of the laser gun is pretty simple – just make a sound effect and fire a laser downrange when the trigger is pulled. The shooting gallery is where all the fun happens. Five dog food cans are lined up at the far end of the range. There’s a small hole in each can and a phototransistor inside each can that activates the ‘fall over’ mechanism. When all the cans are knocked down, a windshield wiper motor puts all the cans upright again.
Thanks to [Kris] for sending this one in. Check out the shooting gallery in action after the break.
Continue reading “Laser Shooting Gallery Made From Scrap”
