You know the old trope: James Bond is killed but it turns out to be someone else in an incredibly good-looking Sean Connery mask. Mission: Impossible and Scooby Doo regularly had some variation of the theme. But, apparently, truth is stranger than fiction. The CIA has — or at least had — a chief of disguise. A former holder of that office now works for the International Spy Museum and has some very interesting stories about the real masks CIA operatives would use in the field.
According to the video you can see below, the agency enlisted the help of Hollywood — particularly the mask maker from Planet of the Apes — to help them with this project. Of course, in the movies, you can take hours to apply a mask and control how it is lit, how closely the camera examines it, and if something goes wrong you just redo the scene. If you are buying secret plans and your nose falls off, it would probably be hard to explain.
Continue reading “Spy Tech: CIA Masks In Five Minutes Or Less”
