Illustrated Kristina with an IBM Model M keyboard floating between her hands.
Keebin’ With Kristina: The One With The Uni-body That Does The Splits
Personally, I love a monoblock or uni-body split. You’ll pry this Kinesis Advantage from under my cold, dead hands. But on the go, I really like the Glove 80, a true split that can be completely wireless in case you want to put the halves really far apart.
A triple-black split keyboard without a case, for now.
Image by [thehaikuza] via reddit
[thehaikuza] is the opposite, preferring a full split at the desk, but finding it troublesome when using it on the couch or at a cafe or co-working space, and so created dǎ bāo (打包) — a uni-body split that can also be a distant split. And this best-of-both worlds creation is remarkably [thehaikuza]’s first keyboard.
The name means to take out food, and if you click the picture you can see a cute little take-out container on the silkscreen of the right half. Directly below it, there’s a track point nubbin to be used with the thumb.
It does its split-in-half trick via a magnetic four-pin connector for when you want the halves stuck together. When the halves are separated, they can instead talk over a USB-C cable. One half has the microcontroller, and the other has a GPIO expander.
Continue reading “Keebin’ With Kristina: The One With The Uni-body That Does The Splits” →
