Pneumatically-Morphing Display Makes Waves
An orange silicone membrane is shown above a translucent 3D-printed block. The membrane has parallel stripes raised above the level of the surrounding membrane, running in lines away from the viewer.
[Soiboi soft] has been building unconventional pneumatic systems for some time, and has recently developed a series of pneumatic displays that use evacuated cavities to depress segments of a silicone face sheet. The mechanism still had untapped potential, though, which [soiboi soft] exploited in the latest iteration: a three-dimensional display which creates smooth patterns of reliefs and recesses.
The pneumatic design is functionally the same as in previous iterations: the display is made up of a matrix of cavities multiplexed to vacuum control lines by a set of pneumatic transistors. In earlier display designs, these cavities were covered by a silicone faceplate, but in this iteration, each cavity is covered by a membrane, on top of which is a silicone pillar connecting it to another top sheet. Thus, when a particular “pixel” is pulled in or out, the faceplate bends continuously, with less pixelation.
Fabricating this silicone sheet was less straightforward than in previous versions. As before, it was cast in a 3D-printed mold, but because of the internal columns, there was no clean way to remove the mold; [soiboi soft] therefore printed that portion in PVA filament, then dissolved it in an ultrasonic bath after casting. The final display gave a truly unique performance, physically reshaping itself into various patterns: checkerboards, spreading ripples, expanding spirals, and static images; in one test, it steered a marble around its surface.
Although we’ve never seen this exact approach before, it is reminiscent of a few other projects, such as this shape-changing tabletop or automated pin-art display.
