Voice Command With No Echo
[Naran] was intrigued with the Amazon Echo’s ability to control home electronics, but decided to roll his own. By using a Raspberry Pi with the beta Prota OS, he managed to control some Phillips Hue bulbs and a homebrew smart outlet.
Prota has a speech application, which made the job simpler. He does point out though, that his project doesn’t replace the Echo’s ability to answer questions by searching the Internet. The advantage, though, is it is easily tailored to your specific application. Also, if you have a Raspberry Pi hanging around, you can’t beat the price. Continue reading “Voice Command With No Echo”
Vocal Mouse Control
[youtube=http://www.youtube.com/watch?v=PXmccs4GIqI]
Absolutely fascinating. The University of Washington is developing a vocally controled mouse interface. We’ve seen vocal control of the computer before, but it is usally responding to specific commands and words to carry out tasks such as opening files.  This system uses different vowels and sounds to create cursor motion.  You can see the same system used in the video above to control a robot arm as well.
[via BotJunkie]
