Looking in the back of the Tektronix 577
Repairing A Tektronix 577 Curve Tracer
Over on his YouTube channel our hacker [Jerry Walker] repairs a Tektronix 577 curve tracer.
A curve tracer is a piece of equipment which plots I-V (current vs voltage) curves, among other things. This old bit of Tektronix kit is rocking a CRT, which dates it. According to TekWiki the Tektronix 577 was introduced in 1972.
In this repair video [Jerry] goes to use his Tektronix 577 only to discover that it is nonfunctional. He begins his investigation by popping off the back cover and checking out the voltages across the voltage rails. His investigations suggest a short circuit. He pushes on that which means he has to remove the side panel to follow a lead into the guts of the machine.
Continue reading “Repairing A Tektronix 577 Curve Tracer”
