While it may or may not be true that if everybody had an ocean they’d be surfing like California, it is true that with a water pump, some copper tape, and a few scraps you can make a surfing simulator that sprays you if you don’t keep your balance.
You can see the simple device in operation in the video below. We presume [Adi_10] actually surfs, but we can’t comment on the realism of the simulator. There’s no computer. Just a switch made from the base and the balance board.
