There was a time when building your own computer meant a lot of soldering or wire wrapping. At some point, though, building a PC has come to mean buying a motherboard, a power supply, and just plugging a few wires together. There’s nothing wrong with that, but [Scott Baker] wanted to really build a PC. He put together an Xi 8088, a design from [Sergey] who has many interesting projects on his site. [Scott] did a great build log plus a video, which you can see below.
As the name implies, this isn’t a modern i7 powerhouse. It is a classic 8088 PC with a 16-bit backplane. On the plus side, almost everything is conventional through-hole parts, excepting an optional compact flash socket and part of the VGA card. [Scott] acquired the boards from the Retrobrew forum’s inventory of boards where forum users make PCBs available for projects like this.
