Hacklet 85: Alternative Audio Amplifiers
When you think of amplifiers, you’re probably thinking of audio or some big ‘ol power amps for radios. While interesting, there are some very interesting ‘alternative’ amplifiers floating around hackaday.io that are more than just power amps, and exceedingly useful, to boot.
1601181393316190625[Ronald] bought an XMS amplifier a few years ago, and although it worked well, every time he changed the input, the loudness had to be toggled. One thing led to another, and he realized this amplifier had a four-channel audio processor that could be controlled by I2C. This was the beginning of his Network Amplifier.
Inside the box is a Raspberry Pi that controls a PT2314-based amplifier. Also included is a 2×16 character LCD, a few LEDs, switches, and a rotary encoder.  There was an Android app that controlled the amplifier, but this was discarded for a better looking web-based solution. Now [Ronald] has every audio source available over WiFi.
973501443636885535What if you want an audio amplifier without a speaker? Wait, what? That’s what [DeepSOIC] is doing with his experiments in ion wind loudspeakers.
‘Ion wind lifters’ have been around for decades now, mostly in the labs of slightly off-kilter people who believe this is the technology aliens are using to visit earth. Nevertheless, ion wind lifters produce an airflow, and if you make that wind variable, you get sound. Pretty cool, huh?
The amplifier for this project uses a tube to modulate kilovolt supply through the ion ‘blower’. Does it work? Sure does. [DeepSOIC] got a piece of 0.2 mm nichrome wire to discharge ions into the air, after which the ions drift into the second electrode. The result is sound, and the entire project is built deadbug style. It really doesn’t get cooler than this.
2981611414932529525Continuing with the tube amp trend, [Marcel] built the cheapest little tube amp around.
The design of an audio tube amp is fairly simple business. First, you start with a big ‘ol transformer, and rectify the AC into DC. This gets fed into a preamp tube, and this is fed into a bigger power tube.
In about 50 years of development, tube designers had the technology down pat by the mid 1950s, and triode/pentode tubes were created. This allowed tube designers to condense two amplifier stages into a single tube. While this setup was usually used for cheap, toy-like electronics, you can still buy the ECL82 tube today.
[Marcel] took one of these tubes, added a rectifier tube, transformer, and big cap to create the simplest possible tube amp. Use it for guitars, use it for hi-fis, it’s all the same. It’s not going to sound great, but it is a very easy amp to build.
All of these interesting audio amplifier projects are curated on this new list! If you have a build that amplifies sound in an interesting way, don’t be shy, just drop [Adam] a message on Hackaday.io and he’ll add it. That’s it for this week’s Hacklet. As always, see you next week. Same hack time, same hack channel, bringing you the best of Hackaday.io!
6 thoughts on “Hacklet 85: Alternative Audio Amplifiers”
  1. Best one I’ve heard is using the gradient amplifiers and coils in a magnetic resonance imaging system to produce musical notes. Examples: https://youtu.be/5bDsfCUJ9Vk?t=32 and https://youtu.be/7MRm5mD2YxQ
    Inside the bore of a 3 Tesla research MRI 15 years ago, I measured some sequences hitting 140 dBA. Normal sequences for patient use can easily hit 130 dBA. (Though current clinical units are quieter now.) The amps we used delivered 330 amps at 750 volts on each of three channels. Beats your average rock concert in intensity, but the audio fidelity sucks.
    1. Do patients undergoing those loud sequences wear ear protection? Because, uh, 130 is the threshold for instant, permanent damage.
      1. Absolutely. For those loud research sequences earplugs plus over-ear hearing protectors were mandatory. Total reduction from the pair or protectors is 35-40 dB (at this point acoustic transmission through the skull becomes dominant).
        Even “quiet” clinical sequences can easily exceed 100 dBA, and ear protection is still required.
