If you’ve been amused by the lengths people go through to speak to a serial device these days. [timmeh] just took the cake. He build his own frikkin’ tiny RS-232 to USB interface with the diminutive SIL CP2101. The package on it is QFN-28 (If PLCC is Darth Vader, QFN-28 is his mean little brother.) That said, if you prefer to work with stuff that talks TTL or RS-232, this could be a handy add-on to pop a USB port on your project. (Oh, look, they have samples…) Sure, we’ve beaten the serial connections to death, but they’re so handy we just can’t resist. It may be a decent way to add a serial port to your laptop. (Picture this: dell’s bluetooth cards are usb devices – you could add one of these without even voiding your warranty.)
15 thoughts on “RS-232 USB Madness”
Leave a Reply to WolfCancel reply
I’d say that your better off by using a FT232R from FTDI ( http://ftdichip.com/Products/FT232R.htm ). It comes in a much more handy SOIC package which can be soldered more easily.
I’ve personally used the heat gun method to re-reflow boards which had become unstable, and htese were not low-pin-count devices either (256-ball MAPBGA, 90-ball VBGA and 64-pin EasyBGA parts) — I found the trick was to use a non-contact thermometer and aim it at the part you wanted to reflow, warm up the entire board and then center in on the part. I brought the surface temp up to about 230-250 degrees C and it seems to work very well. None of the 0603 parts or larger tantalum or electrolytic caps on the other side fell off, either, which was a bonus. :-)
That’s all well and good, now when is somebody going to make something like that for my older midi gear?
Well, fieryluyngs, “somebody” already did:
http://www.ucapps.de/mbhp_usb.html
And if you didn’t know it already, Thorsten Kloose’s site is great anyways!
Cheers everybody.
I’ve been using ft232 for the same purpose to add a console port on a Slug: http://pierreluc.aqra.ca/images/slug/00001.jpg
One could use it with no special tool for soldering.
Madness?
THIS IS SPARTA!!
hmm, I wonder if this method could be used on freescale’s accelerometers withough damadging them? what do you guys think?
Lol you should have warned me… It’ll cost $12 to get that site back up…
but instead how about this
https://muss.cis.mcmaster.ca/~bernast/index.html
shoulda used imageshack in the first place
Site is down due to “Account over bandwidth”
this is more like it nice hack keep up the good work
Google’s Cache grabbed it before the site’s bandwidth maxed out.
http://72.14.209.104/search?q=cache:Z3xLoVzS168J:www.timmeh.bravehost.com/+http://www.timmeh.bravehost.com/&hl=en&ct=clnk&cd=1&gl=us
Serial ports rock. You can do _anything_ with them.
i think a requirement to posting a hack is not to use the so called free hosting sites. or hack a day should host the images
instead of the cache which has no images, just go to where I rehosted the whole site.
http://muss.cis.mcmaster.ca/~bernast/index.html
The new host works great – thank you!
Very nice IC – I just requested samples.
Earlier I was using FT232BM but it is much more intergrated circuit (CP2101). In FT232BM projects it was need to use external oscillator and here if you request professional pcb boards you could put everything on USB plug :)
