Sonar Navigation Jacket
sonar_jacket
[Lynne] had this crazy idea to build a piece of clothing that would give you feedback about your surroundings using sonar. She started with a carefully selected thrift store jacket. She wanted something that looked good and also provided plenty of places to hide electronics. She used the LilyPad system, with a vibration pad and a sonar range finder. When the system detects an object within a certain distance directly in front of the wearer, it warns them with some vibration. Not only is it practical, it looks pretty cool too. Did we mention she designs clothing?
She notes, in the comments section, that while it can detect an obstacle, it cannot detect a void. How could she detect a drop in the floor or a step down?
15 thoughts on “Sonar Navigation Jacket
  1. I was thinking she could use the same as the presence detection, but pointed at a 15 degree downangle. Then just make it vibrate (Differently prefferably) when it no longer detects something within a predetermined range. It should constantly detect unless there’s a void. have it only trigger when it loses input. Loss detectors are pretty simple and commonplace in the sensor world, so it should be easy to come across/build.
  2. good ideas… a large issue with this would be change of input, as the legs would be moving… so the change is constantly happening.
    of course movement would depend on where the sensor is mounted. near the zipper at the base of the jacket might work, but there’s still a good amount of movement there… at the end of the sleeves would be ok, at least the person could keep their hand steady.
  3. You would of course add tolerances for moving up and down. What you would be looking for is a large change in c, as a(length) and b(height) would have minor changes. C, the angle from the sensor to the floor would need to change by 1′ foot or more.
  4. If further developed, a blind person could appreciate this kind of innovation and not have to wear 50 lbs of equipment like previous guidance electronics. Great idea, you could market this.
  5. Void detection could be made pretty accurate if one added a accelerometer at the location of a forward and down pointing ultrasonic transducer. Work out relative position from the accelerometer and subtract from the ranging data.
  6. One could just detect the +difference in distance between signals: Just have a sonar detector set up a constant (walking on level ground) and then only go off when it detects a positive change in distance past a certain threshold.
    But, I don’t know anything about hardware =(
Leave a Reply to Jack Cancel reply
