Monotron Openly Monophonic
Famous synth manufacturer Korg has released the schematics (get them here if you don’t like to fill out forms) for their wee little Monotron for all to see and use! This is great news for anyone looking to build up a synth from scratch or to circuit bend their existing monotron. The filter circuits alone would be fun to add to an existing electronics setup.
Granted there are already many examples of monotron mods out there, but that shouldn’t stop you from experimenting with your own variations. Now with the schematics you can make fundamental changes to the architecture of the synth all from the comfort of your own CAD software. Want more oscillators? Distortion? It’s all out there for you to explore. We’re very interested to see how far people will run with this. And big ups to Korg for recognizing the value of hacking!
[via Retrothing]
17 thoughts on “Monotron Openly Monophonic
  1. Nice! Nothing too unfathomable in there. The one thing that shouts ‘unobtanium’ is the way they drew the Q1 in the VCO, but from what I can tell it’s just two discrete transistors in one package.
    Would be nice if a cheap microcontroller could be made to simulate this so we don’t have to source all those discretes :-)
    1. @Digitalundernet – You could do it… just don’t try -this- circuit for your first attempt.
      Buy a kit synth from getlofi..
      … you get support if you need it..
      … those kits are small enough that you’ll learn what they do.
  2. @Digitalundernet if you want to make your own synth look at either the midibox.org midibox SID or MFOS soundlab.
    Never considered the idea of recreating the schematic in eagle and then modifying it though, thanks for that idea hackaday!
  3. @Digital HaD also has a nice section in the howto tutorials on a pretty simple one. I found the MFOS and it’s junky-crazy webpage to just be too annoying. Ray Wilson is a bit of an asshole. The atari punk console is another easy project to start with. Ya can even google up some radioshack electronic kit videos in which people have done some pretty impressive stuff. Analog Box is a fun piece of software to design circuits with tons of bleep/drone modules made by users. Happy building :)
    I love my little monotron. I’m getting a second one for my b-day to actually crack open and tinker with. Like most say, it is worth it for the filter alone. And it looks like the devs were super nice about making it tinker-friendly from what I’ve seen which is awesome :)
  4. If you’re new to analog circuitry, don’t even think of trying to build this thing all from scratch at once using only a circuit as a reference. Build simple modules one by one, see how they work first, then join them together.
  5. Wanna beat thomas dolby at his own game? Check out the japanese equivalent of PAIA – Gakken. Except they come pre-assembled.
    http://www.youtube.com/watch?v=4XNESJBvPrs
    PAIA… great guy[z], legendary, amazing company… but basically the entire product line should have been rendered to silicon years ago. Bring back the jolt, and get us synthetic patch cords so we can change configs on the fly. The newest products are basically 20 years old. I like classics, but there’s a world of new users out there who want and need features like sampling and cascading reverb units with multiple taps.
    Come on PAIA, you can do it! Give us the weird CV analog synth equivalent of a quad rack setup using surface mount components in a bento-box form factor! Give us an eeprom that will save patches… we know you’re not dead yet!
  6. @Rich Decibels: start with the Line In jack, or the point marked as VCO (TP8). Following it is a buffer amp IC4D which you would need anyway and then left to right there’s the VCF. But you also need the wire marked [cutoff> near IC4B to control it, I guess. There’s also VCF gate input to IC4A.
    Fun stuff, adding it to my endless list of things never to be done.
  7. Note that there are multiple connections to the “Bias” net generated by IC2B (text search the PDF). This is a floating virtual ground enabling the use of single supply rail op amps.
    The little triangle is not ground! ;)
    J
Leave a Reply to Fallen Cancel reply
