Pulse Width Modulation With Microcontrollers
Those following the ProtoStack tutorials will be happy to hear that there is a new installment which explains Pulse Width Modulation. If you’ve never heard of PWM before, it’s a method of generating a signal that is logic 1 for a portion of the time and logic 0 for the remainder of the time. It is the most commonly used method for dimming an LED, and that’s [Daniel’s] example in this tutorial. But you’ll also find it used in many other applications such as servo motor control and piezo speaker control.
[Daniel] starts off with a brief explanation of duty cycle, then moves on to some examples of hardware and software PWM. Many of the AVR microcontrollers have a hardware PWM feature that allows you to configure a pin that toggles based on a target timer value. This is demonstrated using an ATmega168, but a method of using interrupts and your own code is also covered in case you don’t have a hardware PWM pin available.
6 thoughts on “Pulse Width Modulation With Microcontrollers
  1. Hi
    Nice tutorial. Nowdays I am also working on PWM. I i I am able to generate PWM from lookup table. Would like to understand the flow diagram for multiple pwm control. i am doing coding in assembly. also using interrupts. On for duty cycle and other for freq. and there is also typical prob for 100 percent and 0 percent . how you are handeling it?
  2. Perfect timing.. Was just going to start gathering some material to do my own Hackerspace class on servos and steppers. This will help. Is it GPL/copyleft?
    Tweeks
  3. Since PWM is often used to drive sets of three LEDs (red-green-blue), I’ve wondered if there is much difference (power wise) in trying to balance the on-off time (ie: all three on and off at the same time; or only one (or two) on at a time) among the three LEDs. Has anyone seen any research on this?
  4. Great tutorial! Glad to see someone is working on teaching the kiddies the real C code, instead of that Arduino nonsense.
    Keep up the great work!
