[Steven] had one of those musical gift cards laying around, and thought he might as well reuse the piezo speaker inside it. Without a particular project in mind, he soldered an LED to the piezo and tapped on it, which caused the LED to illuminate as expected. He started to wonder what quantity of force would be required to light the LED, and if it could be done by a raindrop.
He first tested his theory in the shower, and as you can see in the video below it actually worked, though the light was dim and sporadic as you might imagine. He eventually discovered that for optimal lighting, the piezo worked best when struck by single droplets falling with pauses in between, from a minimum height of 4 feet. To achieve a water flow within those specifications, he built a rain funnel so that he can control the droplet frequency and intensity.
It seems to work pretty well from what we can see. Off the top of our heads we can’t seem to come up with any practical applications of the water powered LED, but it is an interesting set of experiments nonetheless.
Have an idea to use this setup that we totally missed? Let us know in the comments!
[Thanks, Rob]
