The Vtech InnoTab is a child-sized tablet computer built for kids. Apart from being the ideal solution to keeping the grubby, sticky hands of nieces and nephews away from proper ‘adult sized’ tablets, it can also serve as a Linux tablet perfect for a few homebrew apps. [Mick] picked up an InnoTab for his son, but after getting BusyBox working, we’re thinking it has become a toy for the father and not the son.
[Mick] cracked open the InnoTab and soldered a few wires to a pair of pins that connect to a TTL level converter and then to a TV. There’s a full Linux shell running on [Mick]’s new tablet, encouragement enough for him to start porting ScummVM, the engine behind famous LucasArts point-and-click adventure games of the early 90s.
Right now, it’s still very much a work in progress, but [Mick] has full screen support and a virtual keyboard working; more than enough to enjoy Day of the Tentacle and Sam & Max Hit the Road. After the break you can see the video of [Mick]’s InnoTab running the much more child-friendly SCUMM adventure Putt Putt Goes to the Moon, something we’re sure his son will love.
[youtube=http://www.youtube.com/watch?v=9gI_La66BhA&w=470]
I searched and found more info about this article here.
http://www.wizardmods.net/f446/vtech-innotab-hack-hacking-130417/
your link is no longer available….
This link works:
http://www.digitalworldz.co.uk/285713-innotab-hack-hacking.html
nope doesn’t
Great start to hacking this device!
[Mick] it would be great if you started a project page over on http://www.elinux.org . we already have a wide range of devices such as ones from LeapFrom and FisherPrice that have been documented there.
I wonder what electrical interface the cartridge uses (and whether it could be abused to add peripherals to the bus like on many consoles).
I would also be interested my niece has a pink and purple one. As well as how exactly the hack was pulled off to access busybox?
:D
What is it you want to know mate?
They got the article wrong a little, basically the unit already runs linux and busybox. Just connect those two pins in my photograph to a ttl>rs232 converter and run up minicom or hyperterminal depending on your OS, settings are 115200,8,n,1 are the settings.
Or
If you just want to run your own code you can do the following.
Download SQLLite manager extension for firefox, use it to open innotab.db which is on the SD card.
Go to the “games” section, and create a duplicate entry of one that already exists..
Change the filename on the new entry to something like /vp_mnt/sd/LLN/APPS/myapp
create a folder called on the as card /LLN/APPS/myapp
in that folder create a file called _Run
and put shell commands in there :) and the innotab will execute them.
for instance try ls -aR / >/vp_mnt/sd/LLN/APPS/myapp/dir.txt
Mick
Mick,
what is the voltage of the TTL interface? do you have a datasheet and/or additional information on the processor? i’d like to collect this info over on the wiki page we started:
http://elinux.org/InnoTab
This hardware is still a bit expensive for what it is, but I will be keeping my eyes on the bargain bins for one :)
I think vtech may also be in breach of GPL, as I can’t find any source code downloads for the device.
There is a slight mention of it in the manual that you can download online, but the website pages they mention don’t exist on the Vtech site!
Any one have any thought’s on that?
Also if anyone want’s any more information on the hack, feel free to contact me on
is0mick at yahoo.com
Mick
is0-mick,
already looking into that. it would be great if you started a project page over on the elinux wiki to track all the collected info…
Dave
can you come out with a hack for innotab2s 44.3 and some instructions would be awesome!! thanks so much :)
wow and here it is
yea went ahead and got the base content started…..
info on adding an external 3.5mm uart to the InnoTab
http://elinux.org/InnoTab_3.5mm_Uart
info on adding an external 3.5mm uart connection is now up on the wiki:
Looks like the innotab is Doomed!
http://youtu.be/2Y5mhioTs90
Would be a bit hard to control though..
Mick
Doom, now with accelerometer support!!
Not really suitable for 3yr olds though..
http://www.youtube.com/watch?v=XTHwF1sS8_4
Mick
OMG, Mick, you have renewed my faith in this device. I bought 2 last Christmas, and was just talking to my wife about Craigslisting them. However, I see that the mod community has finally had some time with it and is starting to play!!! I hope that you keep it up, let me know if I can help!
I have tried to compile multiple binaries for the Innotab, even a simple hello
world C app and have had no luck getting them to launch on the innotab. I have
it setup through SD and in the Database it’s set to launch ./testapp (testapp is
the binary name) It says “Loading..” on the Innotab screen.
What command line options did you guys use to compile doom and the emulator?
I have tried armv6 using Yagato and GNU Tools ARM Embedded 4.6 2012q4
Anything you can think of I am doing wrong? I would love to start porting things
just need a kick in the right direction
-Sitedude
OMG someone please tell me how to get into it, I can only see two small screws one is for the lithium battery cover the other seems to open one side. The rubber corner covers seem to hold it together, do I have to force it apart at that point?
It will not switch on, be it on the adaptor or batteries the screen flashes once then that’s it.
I would like to see inside to see if it’s the on/off switch or the screen that’s failed!
Ron M
