Your bench supply doesn’t need to look sad just because you’re using an ATX power supply instead of a commercial product. Follow [Ian Lee’s] example and you could have beautiful wooden enclosures for the tools in your own shop.
The woodworking skills used here aren’t all that advanced, but you need to have a knack for it so we suggest running some test pieces before you start the actual build. [Ian] ran a dado for the front and back panel in each piece of the wood sides. At each corner the inside of the the pieces were mitered at 45 degrees. To put it all together he laid the pieces end to end on a the work bench, then applied painters tape to the outside of the joints. This holds the joints together so that he can flip the collection over, apply glue, and then start hinging the sides into place. It’s almost like rolling up a box.
As with other ATX supply projects we’ve seen [Ian] designed this so that the PSU can be swapped out later if necessary. Instead of wiring his own cable harness he used an ATX breakout board. To get the interface layout he wanted he mounted the banana jacks separately and just ran jumper cables back to that board.
Flammable materials do not belong near a bench power supply enclosure.
Have you seen what’s laying around on most benches? It’s pretty much all flammable…
But seriously though, a power supply of this rating in a wood case is quite safe if proper ventilation is provided (in this case the builder provided some, not sure if it’s enough, but that’s for him to determine). A century of Radio history and 70 years of TV history indicate that power supplies can safely exist inside wooden enclosures…
Kudos to the maker on the build quality… it looks really sharp and your process documentation is great!!!
A century of car history shows that cars can
“safely” operate using lead based gas, a lack of seatbelts, no ABS, no gas gauges, no traction control, no crumple zones, poorly designed gas tanks that catch fire, etc but that doesn’t mean cars from 100 years ago are still good designs.
A wood enclosure looks good but is a bad design choice in close proximity to a switch mode power supply (especially a cheap one) in my opinion. YMMV.
I wouldn’t use the wood as a heat sink, but I wouldn’t consider it flammable. I would consider the pile of dust accumulated in the average computers and power supplies more flammable. I would suspect that it would probably char and stink like wood burning way before it burst into flames. If it was that flammable I wouldn’t have to use lighter fluid on my grill.
Now I wouldn’t want to be the little piggy that built it out of straw either.
After actually reading the article and seeing that he left the power supply electronics inside the original metal case and mounted that inside the box, I have absolutely no reserve about this at all. I see it no more problematic than my power supply sitting on my wooden desk. If you’re that paranoid about wood, I hope you live in a rock house.
Yep those autos were perfectly safe it’s the idiot behind the wheel that makes them dangerous.
The power supply is in a metal case (the one it came in). With wires running to the cover, it is not that much different than your home.
Do you live in a metal framed home with no wood or flammable materials? Because your home likely has 110V and even 220V wires stapled to wood framing, you better get out, because it may burn down.
Is it the way I would have built it? No.
Is it half as dangerous as you make it out to be? No.
Is it the makers choice? Yes.
This is Hack a Day, most of the stuff you find here is dangerous. Overall this is pretty darn safe. I have seen a lot more dangerous things here.
Don’t be dissing on wood dude.
Ask a firefighter about wooden beams vs steel trusses one day.
Is the title a batman joke?
Wait, the breakout board allow only for 1.25 amp ?
Seriously what king of crap is this ? A computer
PSU can spit much more than 20 amp per line…
usefuse
The lack of fuse isn’t his concern (if I understand correctly) it’s the huge waste of the potential power, sure very little is actually wasted but why use a atx supply when a simple 2A wall plug would do the same thing?
Unfortunately, I jumped the gun a little when I saw the breakout board advertised at Dangerous Prototypes and overlooked that little “feature”… I’ll be replacing the polyfuses with something that can carry a bit more current in the near future.
So the board is a “too-safe” prototype? :-)
What seams really strange to me is that nobody yet found that there are ATX PSUs designed for server chasis (eg. 1U) on the market. These can be like quarter size of traditional PC PSUs while having same functionality and approximately same power.
Note that most of them are thinner but longer like this:
http://www.biztrademarket.com/User/199349/bb/–66_hme.jpg
but you can also find some really small but still having better ratio of edges after some googling. like this one:
http://www.roeyuta.com/UploadProductPhoto/2009112813289309.jpg
I don’t think many specifically buy ATX PSUs to use as bench power supplies, most use salvaged hardware. You could get a real bench power supply for little more than what new ATX PSUs can cost.
That’s exactly how this project got started. The only parts I bought specifically for this project was the ATX Breakout Board ($13). The PSU came from an old unused computer and the rest were project leftovers.
I like the idea of a 1U, though. If I happen across one, I may look into replacing the one that’s in there with it since I need a little more room in the box for some other features I’d like to add.
I think that servers can be recycled exactly the same way as PCs :-) just ask your local IT guy, ebay or e-trash junkyard.
What local what? Nothing around these parts but crickets. Population density less than 40 per square mile where I live. I guess that makes me the local IT guy? If I want a used machine it’ll be me that used it.
1U servers have insanely loud fans in them, whereas a full ATX one will normally have something like a 120mm one on the side of it going really slow till needed, so are effectively silent compared to most other noise sources in a workshop.
This is not exactly 1U, it’s just some kind of small PSU… maybe not even from server. i don’t actually know… maybe some micro-itx or whatever…
Anyway you can still add some fan speed regulation based on temperature as you will not load it so heavily and as server hardware tend to not regulate anything at all…
Problem with those small 1U PSUs is cost and heat. A new purchase will be much higher than a normal ATX unit.
Also they are meant to be in a large airflow, servers have no requirement to be quiet so have loads of small fans blowing through them like a hurricane, I certainly wouldn’t like that on my desk.
It is a nice wooden case. I never go so crazy finishing the boxes I make for my electronics projects. I save my fine finishing for regular woodworking projects. As long as parts are contained and protected I’m good with it. Sometimes I use gutted PC PSU cases as project boxes in fact.
I wouldn’t worry about the wood box catching fire either. That is just foolishness.
This wasn’t built for any specific project. This is going to be a permanent addition to my office and I was looking for something a little nicer than an ATX PSU with some banana plugs screwed into it ;)
I kind of like how bare ATX supplies look myself. I use them as project boxes a lot. I suppose with a paint job an ATX PSU could look better though.
Not “all that advanced” he writes?
What’s it take – dovetail joinery?
Good aesthetics.
I think you should start selling them; w/ options for acrylic or aluminum front/rear panels.
Thanks. But, with the time that goes into even a project this small there’s no way to ever charge a fair price that many would pay. The best I can do w/o some persuasion is post as many details as I can so that others can enjoying making their own as I did.
Use that empty space to store the power cable.
(I know, it’s for the volt & current meters, but there’s plenty of space for both.)
What is it with dovetail joints that everyone thinks they’re the pinnacle of wood joinery?
Forget your options for a moment and say what you think a case like that could be sold for? I did some rough calculations and I’ve come up with a number for what would be economically sustainable. I don’t think the market would go that high.
So I’m curious what you think the price should be.
It’s a good idea to use break-out board, but then you don’t have too much amps.
1) good wood working, im impressed with the container and mounting
2) BUT i just dont get it, and i probably never will…
i always thought the whole point of using a PCpowersupply was to avoid the whole spending money on a workbench powersupply thing
why is everyone purchasing breakoutboards worth more then the PS? i mean a used ATX supply goes for 5$ maybe 10$. your spending more money on something then its worth.
you REEEALLY do not need it. why is everyone always so damm scared to cut the whole damm connector off the thing? i mean it WAS garbage!
people dont pick broken TVs worth 50$ and pay 75$ to get them professionally fixed!?!?!?
(ATX is NOT vintage)
mainboard connectors change every few years…
wont be useful for your (future-new) computer in two years.
your spending money to save money??? 13$ plus shipping plus taxes? you can pickup a WHOLE BOX full of PCpowersupplys at the local computer repair shop FOR FREE! usually most of them work
FREE: for that price i gladly cut off the connectors and and and…
That look like a really good job, mine would be as rough as hell.
I like the led’s and the knobs, looks like it was made in the fifties!!
I want one!!
