Large Area X-ray Detector
This is an x-ray detector built by [Ben Krasnow]. It’s an interesting combination of parts working with an oscilloscope. The result is an audible clicking much the same as you would hear from a Geiger counter
He’s measuring backscatter, which is the reflection of x-rays on other objects. Because the signal will be quite weak compared to waves emitted directly from an x-ray source he needed a large collector to measure them. He started by gutting an x-ray image intensifying cassette. This has a phosphor layer that glows when excited by x-rays. The idea is that the glowing phosphors do a better job of exposing film than direct x-rays can. But [Ben’s] not using film. He built that pyramid-shaped collector with the phosphor material as the base. At the apex of the pyramid he mounted a photomultiplier tube (repurposed from his scanning electron microscope) which can detect the excited points on its surface. His oscilloscope monitors the PMT, then issues a voltage spike on the calibration connector which is being fed to an audio amplifier. Don’t miss his presentation embedded after the break.
[Ben] mentions that this build is in preparation for a future project. We’d love to hear what you think he’s working on. Leave your guess in the comments section.
17 thoughts on “Large Area X-ray Detector
  1. I wanted to do EXACTLY the same thing with glass reflectors and a RCA teacup photomultiplier, in order to detect X rays created from CRT displays.
    I have used similar setups though…
    …I hope you protect yourself when you use X-rays
    Really nice work!!!
    1. I sure didn’t see this coming… nice clean, sharp interface, but, uhh… this is going to take me a while to adjust to.
      I guess forgoing any announcements of impending change is one way to avoid a preemptive crapstorm….
      1. also, for some reason, it *really* hurst my eyes. Not in a sarcastic “10,000 razorblades sort of way”, but literally. I don’t know how else to describe it. It hurts to look at the new page design. I hope that’s only temporary.
      2. Uhh, hurts. Not hurst. Derp. Sure would be nice to have an edit button for comments…
        And I still have a missing cursor line… if I want to click back into something I’ve already typed, I have to click where I want to go and then hope that I’ve clicked properly. Until I type and see letters appear, I have no indicator of where the cursor is… this has been going on for quite some time (and only on HAD, fwiw), and the new update hasn’t changed that odd behaviour.
      3. “hurst my eyes” is that a pun to say “it’s killing your eyes”? hehe fitting mistake for the comment I thought.
        *Rob not sure about your cursor problem, I use firefox and have never, nor do I now have that problem.
  2. I bet the project is a one-way x-ray device that uses backscatter to detect objects using the transmitter and receiver on the same device.
  3. Looks cool. BTW has anyone ever tried to use -50V biased solar cells + scintillator film to make a cheaper version of this?
  4. Hi,
    i made also a x-ray detector for imaging using a Lanex Fine screen and a canon camera if some working on same we can share the information so please send me your email address.
    Regards
Leave a Reply to throwawayCancel reply
