Stopping A Hackerspace From Rusting Away
steel
The illutron hackerspace in Copenhagen makes their home on a barge sitting in port. Not only is this awesome, but the members of the hackerspace also worry about corrosion to their beloved fablab. In an effort to ally some fears about rust slowly eating through the hull, [Dzl] has rigged up a cathodic protection system for their hull, essentially preserving their barge at the expense of a few old steel rails.
Cathodic protection systems are able to protect the steel of a ship’s hull by offering up a sacrificial anode made of aluminum or zinc. This can be done by either attaching a sacrificial anode directly to the hull, or with a more complex system that connects both the cathode (the ship) and the anode (an engine block) to a DC power source.
[Dzl] is converting mains voltage down to 12 VDC, then further lowering the voltage with an Arduino-controlled buck converter. The control panel allows for adjustments in the voltage, as well as a nice uptime meter to make sure it’s running.
The results are fairly impressive; in the above pic, the right piece of steel was electrically connected to the barge’s hull, while the left piece was free to rust in the North Sea. That’s only two days worth of corrosion there.
17 thoughts on “Stopping A Hackerspace From Rusting Away
    1. Well… technicall Copenhagen is not in the Baltic sea, but in Øresund, which is the sound (as in body of water) between Denmark and Sweden. To the north of that is Kattegat (between rest of Denmark and Western Sweden), to the south is the “east sea” (Østersøen) which is between Denmark, Germany and Poland.
      Baltic sea is way way up north to the east of Sweden.
      So, now we have placed Copenhagen right.
  1. Just a small note re: going to drydock, illutron is a nearly 70 year old, 480 ton barge, in Denmark, we’re never going to drydock :) Too heavy, and too expensive. Maybe, one day if we were towed to somewhere in Eastern Europe, we could afford to be lifted out and fixed up in dry dock – but then the towing would cost too much. So, our choice is an anti corrosion system.
  2. This was convenient for me that this came up. My family owns a company that is battling galvanic corrosion on several VERY high dollar green houses that are sitting on lime. The aluminum lexan panel retaining extrusions are turning into a goop that looks like wet silicone. I think the Aluminum itself is acting like a sacrificial anode for the steel support pipes. Not sure if I can get away with driving some sacrificial aluminum anodes all around and giving them some good juice or if I need to go magnesium…
    1. if your relying only on the metal, go with something more reactive than what your trying to save, so Zinc or Magnesium, would be the optimal things. also electrically isolating the greenhouse from steel or other metals would help. if your relying on a – electrical charge you dont really need a sacrificial element.
Leave a Reply to pcf11Cancel reply
