Copper Electroplating The Cheap And Safe Way
[A_Steingrube] has posted a guide to his favorite method of copper electroplating. Plating copper onto other metals is popular with the steampunk crowd, but it does have other uses. Copper plate is often used as a prep step for plating other metals, such as nickel and silver. It also (usually) increases the conductivity of the metal to be plated. [A_Steingrube] is using the copper acetate method of plating. What is somewhat novel about his method is that he chose to make his own electrolyte solution from household chemicals. The copper acetate is created by mixing distilled vinegar and household hydrogen peroxide in a 50/50 ratio. The mixture is heated and then a piece of copper scouring pad is placed in. The scouring pad is partially dissolved, providing copper ions, and turning the solution blue.
The next step is to clean the material to be plated. [A_Steingrube] uses Cameo Aluminum and Stainless cleaner for this, though we think any good degreaser will work. The actual electroplating process consists of connecting a piece of copper to the positive terminal of a 6 volt battery. Copper scouring pad is again used for its high surface area. The material to be plated is connected to the negative side of the battery. He warns to keep the solution and the material being plated in constant motion to avoid heavy “burn spots”, which can flake off after the plating process. The results speak for themselves. As with any bare copper material, the electroplated layer will quickly oxidize if not protected.
56 thoughts on “Copper Electroplating The Cheap And Safe Way
  1. Finally an easy to follow tutorial for electroplating that uses household materials! I tried doing some electroplating some time ago with a hacked up PC power supply, it seemed to kind of work, but it took a long time for a coat that rubbed off by finger pressure alone. I’m going to have to try again now following this tutorial
    1. I’ve seen some videos on Youtube and some suggest that a higher voltage does not equate to better plating results. People seemed to be using voltages in the 1.5 to 3 volt range to me with good results. So you were probably plating at too high a voltage for the best results using a PC power supply.
      A lot companies that make copper coated scouring pads must know how to plate pretty good. Because many copper colored scouring pads are only copper plated, not solid copper.
      1. If I recall correctly, the most powerful rail, amp-wise, is the 5V rail. So, it’d probably be less efficient, but this guy is using a 6V battery, so it should still work at least.
        1. On a PC power supply, the most powerful rail, amp-wise, is the 12v rail, not the 5v rail… On a mid range PSU, the 5v rail typically has the lowest number of amps, followed by the 3.3v rail then the 12v rail (which has the highest if it’s a single rail design)… You typically see about 15-25 amps on the 5v rail (depending on the PSU’s total wattage), which should be more than enough.
          1. Um. Not really. Most PSUs have the power rating printed on the side of the unit. I’ve just dug a spare out of my junk box, & it’s ratings are: 5V @ 30A, 3.3V @ 26A, & 12V @ 27A. Ratings vary, but this is a pretty typical unit.
            Any of those current ratings are more than enough for plating parts of the sizes mentioned in the article.
            I’d recommend using the 3.3V rail.
          2. Unable to reply to the lower comment, so replying here.
            “5V @ 30A, 3.3V @ 26A, & 12V @ 27A.”
            Ummm…
            5v @ 30A = 150W
            3.3V @ 26A = 85.8W
            12V @ 27A = 324W
            So, the 12V rail puts out more than twice the power.
      2. The Redox potential of Cu/Cu2+ is only around 0.5V, so you only need a 0.5V potential difference to cause the copper ions to come out of solution. You may need an extra 0.5V to account for the copper being put into the solution, so you’d need something like 1V max.
          1. Resistance is a function of copper ion density in the solution, and the surface areas of the cathode and anode. So using a copper scouring pad lowers resistance, allowing more current to flow.
            Memory check: positive ions are cations, right? Attracted to a [negative] cathode? And the [positive] anode is the copper scouring pad?
    2. Hey if you were trying to plate steel the reactivity index of copper and aluminum to steel is very bad so it won’t work. You have to first plate with nickel or zinc and then plate with copper. Keep ventilated as the salt can produce Chlorine gas
  2. I’m curious if this solution and process would be applicable to electroforming? I know the power requirements are different.
    1. It’s fine as long as you don’t spend them or try to pass them off as currency. Defacing U.S. currency is left over from when the value of money was based on the actual metal that the coin was made of. If you damaged a coin, you might reduce its value. Even then, defacing the coin was okay if you didn’t use it as cash afterward.
      1. It’d have to be really thick — since a modern US quarter-dollar coin doesn’t have 25 cents worth of metal in it. Fiat currency sucks.
    2. Yep, I don’t own those coins in my pocket, the Federal Government does. Elongated coin collectors better watch out!
      (just tell everyone you make really crappy jewelery)
    3. You can do anything you want to US coinage and currency. What you CAN NOT do is alter it to falsify its value, ( Alter a $10 bill to look like a $100 bill, or alter the date on a valuable coin to increase its value ) You CAN cut, tear, plate, drill, etc to any US coin or currency.
  3. Some basic ideas in electroplating are generally that the cleaner the substrate, the better your results will be.
    Also, controlling the current is one of the most important process parameters because plating at too high of a current rate can deposit metal in an uneven fashion resulting in a coating that does not look good or adhere well.
    For example, there is a classic chemistry demonstration where a clean copper object is placed into a solution of silver nitrate. Silver is precipitated as a coating or as needles/lumps/deposits onto the copper object which is partially oxidised, turning the solution blue due to the dissolution of copper ions. Even when this forms a nice smooth coating due to low reaction rates in a dilute solution at low temperatures, it will still form a very poorly adherent silver plating…. It easily falls off at the slightest touch.
    Although many metals can be electroplated there is a reason why getting durable, adherent, and visually bright coatings is such a specialty process that involves lots of study and development. The initial idea that all you have to do is put two metal objects in an electrolyte solution and run some DC electricity to do all these fancy coatings is a miserable oversimplification.
  4. I guess what I am saying is that there is a reason that they have long used copper cyanide in industry. It’s not because playing with cyanide compounds is fun.
    1. In 1964 I was working for Southwest Silver in Oklahoma City. All of our solutions were cyanide based chemistry. Our biggest business was in cleaning, re-plating and coating with lacquer fancy silver settings from some of the more well to do members of our society. Copper plating was always done and polished completely before plating with silver. The better plate material was brass as a base. Jack would usually turn away any items that had a ferrous base. It was too costly to the chemistry. Clayton Plating was next door and I worked for them when times were slim at S.W. Silver. We did Chrome, nickle, cadmium and there was another process I was never involved with that had to do with building up surface diameter with hard chrome for the USG. I remember that my Boss Jack would sweat green in the summer time from all the solution he absorbed over his lifetime. He died of Cancer at an old age, somewhere just above 56 I believe. Remember I was about 16 at the time so he was an old guy. I learned a lot about life working for those two companies.
  5. Distilled vinegar and hydrogen peroxide (with salt) is what I use for PCB etchant. (Previously described here at Hackaday.) So I can take advantage of my used etchant and use it as the electroltye solution for this method?
    1. Yes. Because the dissolved copper from your PCBs is still in the solution (and more pure than the copper plated scouring pad he used in this article), so all you would need to do is add something made of copper to the positive terminal of the battery and your piece to be plated to the negative terminal while both are submerged in the solution… Although I’m not sure if the added salt will affect the plating process or not, I don’t think it would be a problem, but then again, I’m no expert on the subject…
    1. That is copper sulphate crystals. I have used that for making copper plating solutions for plating lead. Dissolve copper sulphate crystals in Hydrochloric with sulphuric acid and you have plenty of copper ions floating around.
  6. keep the dissolved copper at low concentration. The higher the concentration the more likely you are to get a flakily deposit.
  7. best plating = cleanest substrate, lowest current density, lowest electrolyte concentration, and lowest temperature, at the lowest workable voltage…..
    Generally speaking of course
  8. How exactly are bullets copper plated? All the videos i’ve seen require the object to be physically connected to the cathode, which results in the portion touching the aligator clips to not be plated. The Rainer plated bullets i’ve used show no signs of being attached to a cathode physically, and I would assume that it wouldnt be cost effective to have a worker physically connect a cathode to each bullet to be plated when you consider they’re some of the cheapest mass produced bullets out there.
    Please don’t bring up bullet swaging, I all ready know about that and dont have several thousand dollars to drop on a swaging press and dies.
      1. They don’t, also it wouldnt be cost effective because they make millions of them, and they are only attractive at the lowest price point. I started googling it and apparently they use a method called barrel plating in which the anode and cathode never touch the work piece. Now I just gota figure out how to modify my rotary tumbler to be able to do this.
    1. I have no evidence to back this up, but I think it’s more likely that they pour lead into a copper shell, rather than copper plating a formed bullet. It’d be a lot cheaper & faster than plating.
  9. Barrel Plating is the correct answer for many mass processed objects that can survive the impacts at any sane process speed.
    One memorable Hack on Barrel Plate for Hobbyshops was using a perforated plastic pipe- belt turned in a trough made from well casing. Connections were made to metal trough and what the designer called “Throw Plates curved around the pipe’s upper surface but below the solution top.
    Apparently the dismal ratio of plate onto parts vs trough was Good Enough if memory serves.
  10. I’m currious about the solution manufacture only. Being an industrial hard chrome plater for several years has taught me everything else I need to know about plating.
    How distilled is the vinigar? Was it tested with a hydrometer or simply reduced in volume to an estimated or random concentration of acid?
    A length of copper pipe may have been a better choice than copper plated squb pad….even with the berylium of the pipe.
    I plan on using clean copper bus bar personally.
  11. Does anyone know how to copper plate non metallic items,like lace, leaves,pinecones ?id love to copper a bunch of things like that,even if it only sparsely covers them,for holiday ornaments.Thanks in advance !!
    1. I’m currently trying to learn to do this, without much success so far I have been trying a graphie/pva mix, bare conductive paint – water soluble :-( , bare paint mixed with pva, and supper shield graphite paint (evil) – I think the problem that I am having is related to resistivity of the coating, combined with the fact that my (electronics) recitifyer doesn’t seem to want to put out much current through the solution when using these type of carbon coated cathodes.
      I know it’s possible to buy nickle/copper/siler paint, so that might be what I try next.
      1. As kid I was plating all kind of objects, the plating kit was composed of a battery holder for like 6 A cells if I remember right, copper sulfate salt, and graphite paint. Just painting items with graphite paint, a couple of layers if the surface was irregular, and it was providing a good surface for a fairly resistant plating.
        Today I´d rather go vacuum deposition for the conductive layer.
  12. Working with copper chloride and I got my poles backwards. I think I may have made ferric chloride.
    I really have no clue.
  13. Best thing to use i found is in the hardware store it’s called root killer for you sewer contains .99% coper sulfate*** something but it works well and it’s fairly cheep think I paid 13 bucks for a pound it’s a blue granular I was just using water and a old model train transformer a tight coil of 12gage coper wire for the electrode but I might try the peroxide vinegar tonight I’m sure to get better results
  14. I know a lot of people that copper plate things. I also know some people that say chrome plating might be better in some situations. I did not know that copper electroplating was so popular in Steampunk culture, I might have to look into that some more.
  15. How to plate a non-conductive surface with electroplated copper:
    At one time I owned a printed circuit board manufacturing company, where I made PCBs with plated through holes. The final product involved plating solder, 40% tin and 60% lead, onto fiberglass filled epoxy. HOW?
    1. Clean the fiberglass epoxy board and micro etch in a bath of HCl solution, followed by three rinse baths in distilled water. (Caution: this is an acid solution) The distilled water baths very gently wash off any drag-out solution from the previous tank before placing the board into the next tank. The drag-out rinse tanks are eventually rotated, with a fresh distilled tank as the last bath, and the bath tank that was the first bath, is now condensed and then added back into the active HCl solution tank, where the drag-out came from in the first place. No waste into the environment.
    2. Immerse for a short time in a bath of electroless palladium plating solution. The palladium forms an extremely thin, clear, soft, but conductive surface. (Caution: this is a formaldehyde solution) Quickly, to prevent oxidation as much as possible, you want to get the board into a bath and out of the air, follow by three rinse baths in distilled water. Again, eventually, the tanks are recycled.
    3. Immerse for a short time in a bath of electroless copper plating solution. (Caution: this is a formaldehyde solution) Again, quickly follow by three rinse baths in distilled water. This is a soft, but tightly adhering plate of copper
    4. Electroplate a hard layer of copper. Caution: This is a sulfuric acid electrolyte solution with an amino acid leveling agent and a pure copper anode. Voltage is about 1 volt. Voltage is adjusted to obtain a current that is determined by surface area to be plated and Hull Cell analysis of the particular plating tank. Gentle movement is required to provide proper ‘throwing’ so the plating will plate inside the holes in the board, and not just to the outside surface area. Again, follow by three rinse baths in distilled water.
    The board (or nearly any plastic or non-conductive material) now has a hard layer of copper plating on it. It is at this point that a photo resist is added to the copper coated board. Then the circuit pattern is developed in the resist. This is followed by an electoroplate of solder, then by removal of the resist, then removal of the non-solder plated copper, cleaning the solder plate of oxides, adding a layer of flux to the board, heat re-flow of the solder plating, removal flux, cleaning of the board, adding a silkscreen coat of solder resist and a silkscreen of customer information printing to the board. Then package, ship, and collect the easy money.
    To plate solder, which is 60% lead, a very inactive metal that does not like to electroplate, along with 40% tin, a very active metal, and getting the plating ratios right, means the plating tank contains some extremely dangerous chemicals, such as hydrofluoric acid, and control of the tank chemistry and plating currents is not for the experimenter.
  16. Great art! This is the style of details that you should distributed throughout the world wide web. Disgrace to the find search engines without extended location the following upload second! Think about it around plus consult with my website flamingo license plate. Many thanks =)
  17. I worked at a graphic arts company during the late ‘70’s / early ‘80’s, where I did a lot of sheet film processing. The film was called Orthochromatic film. Part of one process involved cutting of a strip off the film with a paper cutter so that the remaning sheet would fit through a film processor. I saved the unprocessed strips for months, made a quart of fixer, and super saturated the solution with silver from the film. I extracted the silver by hooking up a 6 volt lantern battery to a copper penny on the anode and cathode (yes they were made of copper back then). I didn’t know what I was doing, was just tinkering around. I chose the lantern battery because I figured that it would last a long time. I still have the jar of black metallic silver, mixed with some copper from the dissolved pennies I used on the anode. Curious as to what I could do with the black powder.
  18. Hello everybody, i am beginner, i just tried to copper plate on iron in copper acetate that i make from vinegar. The problem is.. When i rinse the iron that had been plated, it goes away. Please anybody to respon my problem.
    Somebody said that the iron must be activated first (i didnt had a clue what he meant)
  19. Hi, I am a homeschool mom who is interested in trying electroforming as a hobby with some of my older children. About an hour ago, we mixed the copper acetate solution and started to electroform a leaf that we had prepared. I was very surprised at the amount of fumes it created. I have a science background and am accustomed to doing all sorts of science in my kitchen, but I am wondering whether or not this is safe to do in our home without a hood. Should we even be messing with these solutions in the kitchen at all? How do you all do this and keep it safe?
  20. Does anyone have a good recipe for good conductive paint or ink and what is best to seal it for electro plating? I am from the UK and we do not have access to acids like the US seems to have.
  21. I tried this method on a piece of iron previously cleaned with detergent and water and then with alcohol. I use 300 mA constant current for 15 minutes . I got a copper deposit that is easily removed with water and a cloth. The piece shows spot af copper but more like a stains than a deposit. I tried several time including degreasing the piece with a houshold degreaser and with more time until 30 minutes but I got always the same result.
    Any ideas that can help me?
  22. Earleishere:
    Interesting conversations on the plating problems people have had and what they are trying. I’m looking at putting a thin layer of copper on brass to reduce r.f. losses. Think skin depth.
Leave a Reply to Carlos Alberto BalseiroCancel reply
