At the end of the month my contract with my current employer (no, not Hackaday) will end. With the interviews starting to line up I therefore thought it’d be a nice opportunity to design the PCB business card you can see in the picture above.
It is made of two PCBs soldered together, the bottom one containing the SMD components while the top one only has holes to let most of them pass through. The design was mainly inspired by the first version we already featured on Hackaday although the microcontroller was changed for the (costly) ATMega32u4 and the top PCB was slightly milled so the LEDs may shine through the FR4. The LEDs are connected in groups of 2 (total of 8 groups) to PWM channels and a hidden flash memory allows the card to be recognized as an external 2MB storage using the LUFA library. All source files may be downloaded on my website.
