There’s nothing like a good clock project, and tacking the steampunk modifier on it only makes it better. [José] built a steampunk clock that does it much better than just gluing some gears on an enclosure and calling it a day. This build includes glowing jewels displaying the time in different colors while displaying the a steampunker’s prowess with a pipe cutter.
The body of the clock is a piece of finely lacquered wood, hiding a perfboard construction with a DS3231 real time clock, a DHT22 temperature and humidity sensor, and a light sensor for dimming the WS2812 LEDs according to the ambient light level.
The rest of the clock is a bunch of 12mm copper pipe, elbows, and t couplers. The end of these pipes are capped off with marbles, with the RGB LEDs behind each of the ‘digits’ of the clock. This is a chromatic clock, with the digits 0 through 9 assigned a different color, based on the resistor color code scheme with exceptions for black and brown. Once you’ve figured out how to tell time with this clock, you should have no problem finding that single 56k resistor in your junk box.
You can check out the video of the clock below.
Love it. I was going to make a lamp with a pipe base and shaft for height. Silver soldering works well with the copper pipe but you need enough temperature. The Propane/BBQ gas/LPG will get enough temperature You can even use tin/lead solder if you don’t mind the lead.
The only thing that I would comment on is the use of a mains power cable for low voltages.
…Is not a power cable, is a USB charger with a sheathed cable, It looks older …;-)
Red, Black and Green – sure looks like a power cable to me. These cloth sheathed cables were used for heating devices like irons, toasters etc.
This is great. DO you have an English version of the instructions?
This is so awesome! I’ve never seen a resistor code clock before :3
Agreed! One of those “how’d I not think of it”s!
That’s awesome!
Fantastic! I want one.
Excellent use of copper pipe!
