Arduino Makerbeam Live Plotter Controlled By HTML5 Canvas And Java Website
We’ve never seen someone build a plotter out of buzzwords, but [roxen] did a really good job of it. The idea is simple, place the plotter over a sheet of paper, open a website, draw, and watch the plotter go. Check out the video below the break.
The user draws in an HTML5 Canvas object which is read by a Java Web Server. From there it gets converted to serial commands for an Arduino which controls the steppers with two EasyDrivers.
The build itself is really nice. It perfectly meets the mechanical requirements of a pen plotter without a lot of fluff. The overall frame is T-shaped, for the x- and y-axis. The movements are produced by two steppers and acetal rack and pinion sets. The pen is lifted up and down by a hobby servo.
We like the use of rubber end caps to hold the frame fixed with friction against the table and a single ball bearing to to contact the table in the direction of its movement. This has the added benefit of being a 3-point contact that automatically squares the assembly to the same plane the paper is in. Any twisting of the frame will have little effect on its drawing ability since it’s end-effector is a ballpoint pen.
We really enjoyed this project, and think it would be fun to play around with. You could hack it to take text input, and output the handwriting you would have if you were replaced by a unconvincing robot copy of yourself.
Thanks for the tip [Daniel R.]!
8 thoughts on “Arduino Makerbeam Live Plotter Controlled By HTML5 Canvas And Java Website
    1. Most commonly, there are holes through the side of the rack that let you attach it without disturbing the tooth profile. Sometimes there is a counter bored or counter-sunk hole in the middle of it for a fastener.
Leave a Reply to Gerrit CoetzeeCancel reply
