Well Engineered Radio Clock Aces Form And Function
Clocks that read time via received radio signals have several advantages over their Internet-connected, NTP-synchronised brethren. The radio signal is ubiquitous and available over a fairly large footprint extending to thousands of kilometres from the transmitting antennae. This allows such clocks to work reliably in areas where there is no Internet service. And compared to GPS clocks, their front-end electronics and antenna requirements are much simpler. [Erik de Ruiter]’s DCF77 Analyzer/Clock is synchronised to the German DCF77 radio signal, which is derived from the atomic clocks at PTB headquarters. It features a ton of bells and whistles, while still being simple to build. It’s a slick piece of German hacker engineering that leaves us amazed.
Among the clock functions, it shows time, day of the week, date, CET/CEST modes, leap year indications and week numbers. The last is not part of the DCF77 protocol but is calculated via software. The DCF77 analyzer part has all of the useful information gleaned from the radio signals. There are displays for time period, pulse width, a bit counter, bit value indicator (0/1) and an error counter. There are two rings of 59 LEDs each that provide additional information about the DCF77 signal. A PIR sensor on the front panel helps put the clock in power save mode. Finally, there is a whole bunch of indicator LEDs and a bank of switches to control the various functions. On the rear panel, there are RJ45 sockets for the DCF77 receiver antenna board, temperature sensor and FTDI serial, a bunch of audio sound board controls, reset switches and a mode control switch.
His build starts with the design and layout of the enclosure. The front panel layout had to go through a couple of iterations before he was satisfied with the result. The final version was made from aluminium-coated sandwich-panel. He used an online service to photo-etch the markings, and then a milling machine to carve out the various windows and mounting holes. The rear panel is a tinted acrylic with laser engraving, which makes the neatly laid out innards visible for viewers to appreciate. The wooden frame is made from 40-year-old Mahogany, sourced from an old family heirloom desk. All of this hard work results in a really professional looking product.
The electronics are mostly off the shelf modules, except for the custom built LED driver boards. The heart of the device is an Arduino Mega because of the large number of outputs it provides. There are seven LED driver boards based around the Maxim 7221 (PDF) serial interface LED drivers – two to drive the inner and outer ring LEDs, and the others for the various seven-segment displays. The numerous annunciator LEDs are driven directly from the Arduino Mega. His build really comes together by incorporating a noise resilient DCF77 decoder library by [Udo Klein] which is running on a separate Arduino Uno. All of his design source files are posted on his GitHub repository and he hopes to publish an Instructable soon for those who would like to build one of their own.
In the first video below, he walks through the various functions of the clock, and in the second one, gives us a peek in to its inside. Watch, and be amazed.
Thanks for the tip, [Nick]
https://www.youtube.com/watch?v=ZadSU_DT-Ks
https://www.youtube.com/watch?v=sP-b0La4Qb4
22 thoughts on “Well Engineered Radio Clock Aces Form And Function”
  1. That is certainly a level of finish to aspire to. If I lived where such a unit was useful I’d build it with a wifi ntp server so that everything else nearby could update from it. I’ve got to use GPS or the usual ntp via the internet, but with an optical link that never goes down anyway.
  2. silly question – and maybe im just not taking the term “front end” literally…but i just built a GPS clock the other day that serves NTP and fits in my pocket with two PCBs and a little code. i fail to understand how this solution is “simpler”. can anyone clue me in?
    also – definitely dont want to distract from the build (which is STUNNING). really great work here.
    1. I think the simpler comes from the electronics. The gps module is a complex (if now cheap) module doing fancy signal receiving, tracking multiple satellites, computing differences and then coming out with the time. The time element here is just receiving an on/off radio signal well above the noise floor, checking it makes sense then syncing a clock to it. The radio clock signal is so simple you could decode it by hand however I wouldn’t want to solve gps by hand.
    2. A GPS receiver is much more complicated than a DCF77 receiver (and it uses more power). DCF77 is just a 77kHz AM signal.
    1. Sunday has been the first day of week since antiquity look at a calendar. However, ISO 8601 starts with Monday as the first day. Some calendars follow ISO 8601 mostly in Europe. Sunday is not wrong just depending on what your referencing. It’s actually interesting a lot language the word Monday is second day. I think the days of the week in Portuguese is a good example.
    2. Sunday is the most common starting day for the week. Go to google images and type in calendar and see what shows up.
  3. I think this is a perfect kit to sell on Kickstarter with different wood options and a circuit option to have a wifi ntp server to sync time on your network.
  4. Nice clock. It explains the time-signal a lot better than reading about it. Reception of the DCF77 radiosignal in noisy electric and concrete surroundings can be a bit problematic and most clocks don´t display what they are doing.
