A Floppy Drive For Apple’s Pippin
The Pippin was Apple’s first and last foray into gaming consoles. At its heart, the Pippin was a strange ‘multimedia device’ with a CD-ROM, the potential for Internet access, a few neat controllers, and the guts of a very bare-bones PowerPC Macintosh. Think of a cross between a 3DO and WebTV, and you’ll get an idea of what Apple was trying to build here.
The Pippin is rare, and that means the related accessories, ranging from magneto-optical drives to floppy drives, are incredibly hard to come by. Now, one of those peripherals isn’t rare anymore; [Pierre] has cloned the (passive) PCB that allows a Macintosh floppy drive to plug directly into the Pippin.
The expansion capabilities for the Pippin are locked away inside a PCI connector strategically located on the bottom of this set-top box. The official floppy drive accessory injection molded case, a standard Mac floppy drive, and a PCB. After finding one of these rare floppy drive accessories, [Pierre] simply took a meter to all the pins, traced out the circuit, and created a PCB with a PCI connector on one end, and 20-pin connector on the other. The PCB is shared on OSH Park if you want to check this out.
Although recreating this hardware was relatively easy, testing it was not. The first test used the Floppy Emu, a neat device that allows old Macs to read disk images off an SD card. This worked beautifully, but testing it out with a real floppy drive did not. Some disks simply didn’t work, although [Pierre] is chalking that one up to a problem with the USB floppy drive and a Mac running Sierra.
5 thoughts on “A Floppy Drive For Apple’s Pippin
  1. [Pierre] has cloned the (passive) PCB that allows a human centipede and Macintosh floppy drive to plug directly into the Pippin.
  2. On making disks to test a real floppy drive with the adapter I say he should find an oldworld rom power mac as working ones very common and cheap on ebay.
    1. yeah, i didn’t know what Sierra is. (High Sierra Format for CD’s, eh?) ..but i do consider usb floppy drives to be terrible in general and newer OSX’s are terrible for reading/writing HFS of floppies and accessing SCSI storage. anyhow, “cheap” is subjective and depends on what part of the world a buyer lives; the “Get a Mac” advice is smart though.
